IR 829 LAN ports not able to access internet
ddolbel
Hello Cisco Community, I'm hoping you can assist me...
Don't know what happen, buy my post disappeared.
I have a IR 829 router that can ping the internet
GLE-CE-02#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/34/40 ms
However when I connect any clients to the onboard lan ports they are not able to browser the internet.
I'm pretty sure I'm missing something just can't put my finger on it, any help would be greatly appreaciated.
Here is my config
GLE-CE-02#sh conf
Using 6034 out of 262144 bytes
! Last configuration change at 15:35:41 AEST Fri Apr 23 2021 by lcladm
! NVRAM config last updated at 15:38:47 AEST Fri Apr 23 2021 by lcladm
version 15.8
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service linenumber
service sequence-numbers
hostname GLE-CE-02
boot-start-marker
boot system flash:/ir800-universalk9-mz.SPA.158-3.M6
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging userinfo
logging buffered 51200 informational
logging rate-limit all 10000
logging console informational
enable secret 5 <removed>
no aaa new-model
ethernet lmi global
clock timezone AEST 10 0
clock summer-time AEST recurring 1 Sun Oct 2:00 1 Sun Apr 2:00
service-module wlan-ap 0 bootimage autonomous
ignition off-timer 900
ignition undervoltage threshold 11 000
no ignition enable
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause rootguard
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
ip dhcp excluded-address 10.250.3.20 10.250.3.254
ip dhcp pool GuestOS
 import all
 network 10.250.3.0 255.255.255.0
 default-router 10.250.3.1
 dns-server 8.8.8.8 4.4.4.4
ip domain list <removed>
no ip domain lookup
ip domain name <removed>
ip name-server 10.2.0.100
ip name-server 10.2.0.20
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid IR829GW-LTE-GA-ZK9 sn <removed>
no crashinfo-deletion enable
username lcladm secret 5 <removed>
redundancy
controller Cellular 0
 lte sim data-profile 1 attach-profile 1 slot 0
 lte sim fast-switchover enable
 lte failovertimer 5
 lte modem link-recovery disable
interface GigabitEthernet0
 no ip address
interface GigabitEthernet1
 no ip address
 duplex full
 speed 1000
interface GigabitEthernet2
 no ip address
interface GigabitEthernet3
 no ip address
interface GigabitEthernet4
 no ip address
interface Wlan-GigabitEthernet0
 no ip address
interface GigabitEthernet5
 no ip address
 shutdown
 duplex auto
 speed auto
interface Cellular0
 ip address negotiated
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 ip virtual-reassembly in
 encapsulation slip
 load-interval 60
 dialer in-band
 dialer idle-timeout 0
 dialer string lte
 dialer-group 1
 ipv6 address autoconfig
 async mode interactive
 routing dynamic
interface Cellular1
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 encapsulation slip
 load-interval 60
 dialer in-band
 dialer string lte
 dialer-group 1
 routing dynamic
interface wlan-ap0
 no ip address
interface Vlan1
 ip address 10.250.3.1 255.255.255.0
 ip nat inside
interface Async0
 no ip address
 encapsulation scada
interface Async1
 no ip address
 encapsulation scada
ip forward-protocol nd
no ip http server
no ip http secure-server
ip ftp source-interface Vlan1
ip tftp source-interface Vlan1
ip nat inside source list 1 interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
ip tacacs source-interface Vlan1
ip ssh version 2
ip radius source-interface Vlan1
logging source-interface Vlan1
dialer-list 1 protocol ipv6 permit
dialer-list 1 protocol ip permit
ipv6 ioam timestamp
snmp-server community <removed> RO
snmp-server community <removed> RW
snmp-server ifindex persist
snmp-server location <removed>
snmp-server contact <removed>
snmp-server enable traps wpan
tacacs-server directed-request
access-list 1 permit 10.250.3.0 0.0.0.255
control-plane
line con 0
 session-timeout 60
 exec-timeout 60 0
 privilege level 15
 password 7 <removed>
 logging synchronous
 login local
 transport output telnet
 stopbits 1
line 1 2
 stopbits 1
line 3
 script dialer lte
 no exec
 transport preferred none
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 rxspeed 100000000
 txspeed 50000000
line 4
 no activation-character
 no exec
 transport input all
line 8
 no exec
 rxspeed 100000000
 txspeed 50000000
line 1/3 1/6
 transport output none
 stopbits 1
line vty 0 4
 exec-timeout 60 0
 logging synchronous
 login local
 transport input telnet ssh
 transport output telnet ssh
line vty 5 797
 exec-timeout 60 0
 logging synchronous
 login local
no scheduler max-task-time
ntp logging
ntp update-calendar
ntp server 127.0.0.1
no iox hdm-enable
iox client enable interface GigabitEthernet5
no iox recovery-enable
end
balaji.bandi
Add inside and test it.
BB
5 Replies 5
balaji.bandi
BB
Hi BB thank you for your reply, I added the inside to the NAT statement and tested it, still no go.
I have updated my config in the original post to reflect its new state
I can't ping any addresses from the vlan interface see below
GLE-CE-02#ping ip 8.8.8.8 source 10.250.3.1
Packet sent with a source address of 10.250.3.1
Success rate is 0 percent (0/5)
GLE-CE-02#
GLE-CE-02#
Success rate is 100 percent (5/5), round-trip min/avg/max = 30/68/196 m
can you post :
show ip interface brief ( i belive your VLAN 1 is down)
show ip route
(i would advise to connect any device to Gi interface, allocate interface to vlan 1( or default should be VLAN)
Like Device should get IP address from DHCP and should be able to work ?
BB
ddolbel
Hey BB, Apologies for the delay in my response, for some reason my post got marked as spam....
Thank you for your reply yes you were right my vlan 1 line protocol was down... couldn't work out why even though i had 2 devices plugged into the lan ports.. I deleted my vlan.dat file and on a whim i erased my config rebooted and then reapplied it and everything is working..
Glad to know the solution works as expected. happy to hear.
BB
