Is FEX member not allowed to create port channel to extended switch?
richter5087
C6880(config-if)#channel-group 100 mode on
Command rejected (Port-channel100, Gi171/1/0/1): Cross-chassis bundle can have only core ports
trying to create port channel to pointed interface below with getting this error
May I know any resolution for this? or this is the limitation of fex?
Thanks in advance.
balaji.bandi
Nexus FEX we could able to create a Port-channel - but Looks like there is limitation here.
But you can create a Trunk if that works for you-
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/119378-technote-fex-00.html
check below :
– Configuring EtherChannels with combination of FEX Ports from different FEX-IDs or combination of FEX ports with IA parent switch linecard ports is not supported. However, FEX host port channel from the same FEX is supported
- FEX host port EtherChannel load balancing is not supported.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-1SY/config_guide/sup2T/15_1_sy_swcg_2T/instant_access.html?bookSearch=true
BB
8 Replies 8
marce1000
          - Connecting a switch to fex port(s) is not supported
 M.
Thanks for the reply.
We manage to connect few switch to this fex client , we are now facing problem on creating port channel for the uplink interface to this fex client for throughput expansion.
Hope this clarifies.
             - In all circumstances , connecting switches to a  fex is unsupported ,
 M.
balaji.bandi
check below :
BB
Thanks for the info.
Well noted.
Hi Balaji.bandi,
Not really understand below, could you explain this briefly?
However, FEX host port channel from the same FEX is supported.
Thanks in advanced.
pieterh
C6880(config-if)#channel-group 10 mode on
Command rejected (Port-channel10, Gi171/1/0/1): Cross-chassis bundle can have only core ports
-> Po10 is already in us for the link between FEX to the 6880 ?
==>> you need at least  a different channel number for the link to the 3850
Apologies for the typo.
