Bookmark
Subscribe
452
Optical signal issues after C9300 reboot.
inb
Hi.
We are using model C9300-24S-A and 17.9.3 OS version.
HSRP is configured with 2 switch, and the firewall on the upper uplink is operating as Active-Passvie.
If switch 1 is rebooted due to a failure scenario, switch 2 becomes the HSRP Act.
Firewall 2 will also be converted to Act.
And when switch 1 completes rebooting, it sends out a signal before the status of the fiber (SFP) port becomes "up",
so firewall 1 receives this signal and fails-back occurs.
20 to 30 seconds after the firewall fail-back, the status of the ports on switch 1 becomes "up" and communication is established, causing a problem.
This problem can be resolved by using EEM, but I am curious as to whether this is the correct action.
Our site uses the switches below with the same configuration, but the same symptom is not occurring.
C9500-16/24/40X-A, N9K-C9504/9508, N9K-C93180YC-FX3
Only the C9300-24S model is causing a problem by sending an optical signal after rebooting and before the port status is up (the Port Led is also off).
I also tried downgrading the OS to 16.x.x or upgrading it to 17.12.x, but it is the same.
Please help.
balaji.bandi
Post the diagram, if you using sync link via these switches and Monitoring that is expected behavior (as you mentioned)
if you have sync/state link back to back you only Monitor that link the Firewall should work as expected technically.
https://www.cisco.com/c/en/us/support/docs/security/firepower-management-center/212699-configure-ftd-high-availability-on-firep.html
BB
