Bookmark
Subscribe
337
Is it possible /29 over a network?
Not applicable
Hello, Probably a noob question but can't seem to find a decent answer; here goes.
I have a network 192.168.1.0/29, my PE has 192.168.1.1/29, my CE has 192.168.1.2/29 NAT out..., on the LAN portion of the CE, we have a 172.16.1.0/24 network NAT inside..., now; how con I assign 192.168.1.0/29 addresses on devices inside the LAN and still be reachable from the outside network.
internet <---->192.168.1.0/29 <--> 172.16.1.0/24 <---> 172.16.1.0/24 (out to internet but no access from internet) 192.168.1.3-6/29 (out to internet and accesible from the internet).
The addresses used are an example; I am using a /29 public and a /24 private..., I just really need to split that /29 over that /24, being able to reach the 4 remaining addresses from the /29 from the internet via the /24.
I really don't know how to better explain this but I guess you get the idea.
Thanks in advance.
Julio E. Moisa
Could you please provide more details about this section: now; how con I assign 192.168.1.0/29 addresses on devices inside the LAN and still be reachable from the outside network.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Jon Marshall
You don't need to assign the IPs to devices, you can just use static NAT statements on your CE device. Assuming your CE device is a router as an example -
device real IP = 172.16.1.3
device public IP = 192.168.1.3
add this to your router -
"ip nat inside source static 172.16.1.3 192.168.1.3"
note that you may also  need to allow the traffic if you are using acls etc. on your router ie. you should limit access ideally with a firewall.  In addition if you have more 172.16.1.x devices than 192.168.1.x IPs then you can use the same 192.168.1.x for multiple inside devices providing the ports are different.
If you need to do that let me know because the above configuration needs modifying.
Jon
