Is it possible to disable SSL v3 and enable TLS on Cisco IOS?
BS Wu
Appreciate it if someone can confirm whether it's possible to disable SSL v3 on Cisco IOS, and enable TLS instead.
This was flagged by a Nessus security scan.
Seems like it's currently not possible:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuv24653/?referring_site=bugquickviewredir
Thanks in advance
ahmedshoaib
Level 4
Level 4
Hi;
Transport Layer Security (TLS) and its predecessor, Secure Sockets Layer (SSL), both of which are frequently referred to as "SSL” & work on port 443 by default.
If you want to enable on Cisco Router, which I am not sure & need to do little be research.
While on Cisco ASA firewall you can achieve this with 9.1(X) OS.
You need to modify the SSL setting parameters (via ASDM)
Configuration à Remote Access VPN à Advance à SSL Settings:
The min. SSL Version for the security appliance to negotiate as (Client / Server) à TLS / TLS v1.1 / TLS v 1.2
Diffe-Hellman group to be used with SSL à Group 24 – 2048-bit modules
ECDH group to be used with SSL à Group 19 – 256-bit EC
& Custom Encryption (in case of TLS v1.2)
AES256-SHA:AES128-SHA:DHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA:DES-CBC3-SHA
( OR )
AES256-SHA:AES128-SHA:DHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA:RC4-SHARIFAH
Thanks & Best regards;
