Bookmark
Subscribe
348
is it possible to initiate traffic from router for speediest ?
Dr.X
Level 2
Level 2
hi folks
sometimes i want to test the Backhauling speed in cases like LNS/LAC for ISP providers .
I'm wondering if i can make a dump traffic as much as possible to see if the links not congested .
is that possible with cisco ?
cheers
Mark Malone
You can run an iperf test if your looking to do a throughput test between 2 end devices on each side of the ISP circuit , that would probably be your most accurate way of testing if you don't have an physical testers
https://supportforums.cisco.com/document/12068771/iperf-test-measuring-throughputspeed-wlan-client
Joseph W. Doherty
Some Cisco router IOS versions contained a copy of TTCP as a hidden command, but most do not, especially, I suspect, "newer" IOS versions.
For low bandwidth links, you might be able to create some traffic pressure by using the chargen service, or by using ping with maximum packet sizes or perhaps even by listing something like show tech with pagination turned off.
However, except for the TTCP application, Cisco devices don't have software really intended to congest a link.  As Mark noted, for that, you're likely much better off using some form of traffic generator app that will pass traffic through the Cisco device.
