Is it possible to use tacacs and local authentication at the same time on nexus 3500 platform?
BINH_C_LE83
I need to configure some nexus 3500 switches to authenticate one or more users using TACACS and another user using Local authentication simultaneously.  For example, user A, B and C will login using TACACS while user D will login using Local authentication.  Can this be done?  Thanks so much.
Francesco Molino
i've answered the same question for radius.
below the link of the post and my answer. (config is based on radius but it should be adapted with tacacs without difficulty)
https://supportforums.cisco.com/discussion/13045661/radius-authentication-some-group-users-and-local-authentication-another-group
To achieve what you're asking, there are many ways.
I'll give you 3 of them that don't need to play with Radius authentication results:
1. You can configure your aaa command to look on local database and then to radius like:
aaa authentication login GRP-LOCAL-RADIUS local group radius
2. you can configure multiple aaa authentication (1 looking only on local database and 1 on radius) then assign them to different lines (not the best)
Local:
aaa authentication login LOCAL-AUTH local
line vty 0 4
login authentication LOCAL-AUTH
Radius:
aaa authentication login RADIUS-AUTH group radius
line vty 5 15
login authentication RADIUS-AUTH
If you want to play with Radius.
Configure a standard aaa looking into Radius and then in local:
aaa authentication login RADIUS group RADIUS-SRV local
On the authentication rule, you need to send a DROP action when User not found
Hope this helps.
PS: If this solved your issue, please don't forget to rate and mark as correct answer
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Local:
line vty 0 4
Radius:
line vty 5 15
Hope this helps.
Francesco
Thanks, I configured it to look into the TACACS first and then the local and it worked.  Appreciate it.
You're very welcome
Francesco
