Is static NAT only way for DVR/Servers access?
NInja Black
Are static NAT the only way for allowing access to DVR/Server?
I have around 8 DVRs/Servers all in different networks, so 16 command lines for static NAT both ways.
Example:
For 1 DVR access-
ip nat inside source static 10.10.x.x 50.x.x.x
ip nat outside source static 50.x.x.x 10.10.x.x
Please let me know if there is a easier way to do it. The problem is I cant do dynamic as they all are in different locations (networks).
John Blakley
Are you wanting access from the outside of the network? If so, you only need the "ip nat inside" line.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
John Blakley
HTH,
John
