Is there any way to show IPs using an interface?
umbernaut
I simply need to see a list of all IPs using a Cisco 2800 series router.  I know I can run a show lldp command on my switches to get a list of attached devices, and I know this is a layer2 command.  Is there any  way to get a list of IPs that are using that specific router/gateway?  I'm needing to move them off of this gateway and the many different OSes our end-user devices use, and the number of them, make this a daunting task if it cannot be done from the router.
vvijaysa
Hello Umbernaut,
You can try sh cdp nei det
This will get all the IP addresses of your CDP neighbours.
If you have only LLDP neighbours, it is a tough call. Go to the router that does inter-vlan routing and issue the command 'sh  ip arp' to see if the MAC address is one that has been resolved  recently. In that case, the IP address associated with that MAC address is the IP of the device connected to that port.
If the mac address will not yield the IP address.  You can track the  port down and once you do that, look at the ARP table for that segment.
'show ip arp | include '
Vijay
Jeff Van Houten
Level 5
Level 5
You could run a netflow monitor for a few days or more and collect what is traversing the specific interface.
Sent from Cisco Technical Support Android App
