Is this a NAT traversal problem?
richard.dimond
I have a 1841 router with vpn to the internet ISP.
From the outside world I can get to the mail server's outlook web access ip of xxx.xx.xx.140.
I have set up a guest access wirless lan using the 192.168.196.0 network addresses which is able to access ip addresses on the internet.
I need this outbound guest access from vlan 196 to come back in to also access the owa server.
I do not want this vlan to be accessing addresses on the local lan.
I believe thsi is a NAT Traversal problem but what config changes do I need to make on the 1841 router.
Do I simply need a crypto isakmp nat-traversal config entry
I have attached part of the configuration.
Thanks in advance
Richard
Antonio Knox
Level 7
Level 7
I think some type of drawing would help me understand a bit more.  Can you put together a quick visio drawing?
Hope this helps
Antonio Knox
Level 7
Level 7
This command is actually an ASA CLI command, and is overal not required in this scenario.  Per Cisco documentation:
"NAT Traversal is a feature that is auto detected by VPN devices. There are no configuration steps for a router running Cisco IOS Release 12.2(13)T. If both VPN devices are NAT-T capable, NAT Traversal is auto detected and auto negotiated."
For more info on NAT Traversal and how it works in IOS, look here:
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t13/feature/guide/ftipsnat.html#wp1027186
There is also good info on NAT transparency options available to you.
Please rate if helpful.
This is not a Nat Traversal issue but is more of NAT HAIRPINNING issue. This problem can be solved easily on ASA/PIX but incase of an IOS router , you have couple of choises :-
1> Use dns doctoring that will change the dns reply packet from public ip to private. { but since you do not want the pricate vlan access from that guest wireless network ... this isn't a solution for you }.
2> you can have the same public ip on the server as a secondary ip and then make use of route map's on the router to set up a different Next hop for traffic originating from Guest wireless subnet and destined for that Public. This is a tricky solution and you have to research about it, on how to implement it in your case.
Manish
