ISP Handoff to 2950
seth
I have a 2950, the ISP we use gives us a Cat 5 cable with RJ45 connection.
I put it into a very basic configured 2950 and I cannot get to the internet.
I have a PIX 515E and RV320 that connect into this 2950.
They can talk to each other and build VPN Tunnels.
But going to the outside world, no go.
I can swap out the 2950 and put in a plain 5-port Linksys 10/100 switch and I get full connectivity.
So I thought perhaps the cable they were handing us was configured as a cross-over, so I bought another cross-over in line with it and still no go.
All ports are in VLAN 1
FA 0/1 (ISP is going to this port) is set to Speed 100 and Full Duplex.
So what am I missing?
should the port be configured with the switchport mode multi option?
7 Replies 7
seth
Is it the dot1q tagging that is causing the problem?
seth
Any thoughts?
This is the config on the switch
Current configuration : 2639 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Ext_Switch
enable secret 5 $1$/OQS$3l6YKOy7v.r16YAOoBWaX.
ip subnet-zero
vtp mode transparent
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
vlan 2-3,10
interface FastEthernet0/1
switchport access vlan 10
switchport mode trunk  <------I just added this, it was access mode before.
duplex full
speed 100
spanning-tree portfast
interface FastEthernet0/2
switchport mode access
duplex full
speed 100
interface FastEthernet0/3
duplex full
speed 100
interface FastEthernet0/4
duplex full
speed 100
interface FastEthernet0/5
duplex full
speed 100
**************Added this section this morning, have not tested yet******************************
interface Vlan1
ip address x.x.x.x 255.255.255.128
no ip route-cache
ip default-gateway x.x.x.x
ip http server
line con 0
line vty 0 4
login
line vty 5 15
login
end
glen.grant
2950 does not have auto mdix so make sure if you are going other switches you use a crossover .  if the connection to the isp is 100 meg set the port as auto , ISP not likely to have hardcoded the port and this will cause a duplex mismatch . If you have all your ports in the same vlAN  then that should be functionally equivalent to a linksys switch  without mdix capabilty .  Unless you have a specific reason you shouldn't need any ports trunked .
Ok, I will remove the speed settings and see what happens.
Regarding the cable, I Have tried using the cable they hand off to me directly to the switch and I have also tried putting a Cross Over cable in line.....no good either way.
The hand off we get from our ISP comes out of a Cisco Catalyst 4948
Based on the config listed below, I tried the following this morning.
Plugged cable in to FA 0/1, port goes up, but no communication
Put a cross-over cable in line, the plugged into FA 0/1, port goes up, no communication.
Moved the cable to FA 0/3, did the same two things as listed above and the port goes up, no communication.
Did a Write Erase on the switch, then rebooted it.
With no config in place, I did the same things again as above.
Port goes up, speed 100, duplex full....no communication.
I do a sh mac-address-table
There is no MAC address listed for what is connected on FA 0/1
I have my PIX 515E connected on FA 0/2 and it shows a MAC address on that port.
So I have no idea what else to try at this point.
I don't get why a dumb Linksys switch works fine, but putting in a Cisco 2950 breaks it.
what else am I missing?
devils_advocate
Level 7
Level 7
When you do a 'show int fa0/1', does both the status and the line protocol show as up?
duplex full
speed 100
At the moment you have configured the port to be a Trunk which has a Native Vlan of 1, the switchport acccess vlan 10 command is doing nothing.
You need to speak to the ISP and ask them how their side is configured, if its a 4948 as mentioned then they should be able to give you the configuration.
You are connecting to them at Layer 2 so you need to know whether its an access or a trunk port. If its an access port, which Vlan is being used their end. If a trunk, ensure they are using the same native vlan you are.
I tried their connection to me in both port FA 0/1 and port FA 0/3
The Trunk option I added in at a later time, it was not set that way initially.
See my post below.
Results are the same either way.
I have a call into my contact at the ISP, waiting him to call back...but being holiday weekend he may be off till next week.
