ISPF in MPLS
Hi ,
I am looking for benefit of ISPF w.r.t to OSPF as IGP / backbone is running on MPLS
What will be the benefit if we implement ispf & how to check the reduced convergence time
Pls share the command
Br/Subhojit
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Well the benefit should be occasionally reduced time to process the OSPF topology for shortest path.
There's some OSPF command to check time spent actually processing OSPF for shortest path, so I guess you could compare "before" vs. "after".  Trying to predict improvement would be difficult.  Remember impact of any savings very much depends on what part of OSPF topology changed relative to the router doing the shortest path computation.
As per my understanding it is only application for Type 1 & 2 LSA.
Pls confirm
Also share the command
Br/Subhojit
