ISR 4331 Duplex and Speed Settings
tparrettcisco
Just unpacked a new isr 4331 and working on the config.  I need to set the duplex and speed on both interfaces.  So far I have
interface GigabitEthernet0/0/0
description LAN
ip address 10.1.1.218 255.255.255.0
speed 1000
no negotiation auto
interface GigabitEthernet0/0/1
description WAN
ip address 192.168.200.100 255.255.255.0
ip nat inside
speed 1000
no negotiation auto
When I enter duplex full on either interface, the command is accepted (no errors) but when I do sh run again and look at the interface sections it's not listed.
When I run sh int g0/0/0 I see
GigabitEthernet0/0/0 is up, line protocol is up
  Hardware is ISR4331-3x1GE, address is 6cdd.3066.d6e0 (bia 6cdd.3066.d6e0)
  Description: LAN
  Internet address is 10.1.1.218/24
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive not supported
  Full Duplex, 1000Mbps, link type is force-up, media type is RJ45
  output flow-control is on, input flow-control is on
  Last input never, output 00:00:11, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     1880 packets output, 519026 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 unknown protocol drops
     9 lost carrier, 0 no carrier, 0 pause output
So do I have it set correctly?  Will I not see the command listed with the other interface commands? I'm use to working with the older ios where I actually see the command listed within the interfaces.  I'm sure this is easy...what am I missing?
Reza Sharifi
Usually, when you apply a command and don't see it in the running config, that command is turned on by default.
So, most likely the new IOS has full duplex turned on by default.
5 Replies 5
Reza Sharifi
Half-duplex 1G basically does not exist, thus when you enter speed 1000 - it automatically implies it's full duplex.
Joseph W. Doherty
Copper gig switch ports often only support full duplex at gig, as it's assumed anyone running copper gig wouldn't be using or needing gig half duplex.
Leo Laohoo
If you want to hard code the speed and duplex settings, keep an eye out for line errors. The counters for "input errors" should start incrementing.
edward.michels
I just had this same issue. You have to hard code the media type to rj45 with the interface command
media-type rj45
and then you get the option to statically set speed and duplex.
