Cisco 2960XR - SMI Director is not configured, disabling SMI
Anon01013
I booted up a Cisco 2690XR-24PS switch and got this message. I tried looking online to see what the message is and all I can was this (see link). What is this message and is this something I should be worried about? Should I update the IOS just to be safe? Thanks for the help!
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvd36820/?rfs=iqvred
Jan 1 00:02:15.472: SMI Director is not configured, disabling SMI
Jan 1 00:02:15.472: disable_smartinstall_operation:Disabling SMI
switch: boot
Loading "flash:c2960x-universalk9-mz.152-4.E6.bin"...Verifying image flash:c2960x-universalk9-mz.152-4.E6.bin.........................................................................................................................................................................................................................................................................................................................................................................................Image passed digital signature verification
File "flash:c2960x-universalk9-mz.152-4.E6.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(4)E6, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Thu 05-Apr-18 02:53 by prod_rel_team
Initializing flashfs...
Using driver version 4 for media type 1
mifs[7]: 12 files, 1 directories
mifs[7]: Total bytes : 1806336
mifs[7]: Bytes used : 834560
mifs[7]: Bytes available : 971776
mifs[7]: mifs fsck took 1 seconds.
mifs[7]: Initialization complete.
mifs[8]: 2 files, 1 directories
mifs[8]: Total bytes : 3870720
mifs[8]: Bytes used : 1213440
mifs[8]: Bytes available : 2657280
mifs[8]: mifs fsck took 0 seconds.
mifs[8]: Initialization complete.
mifs[9]: 5 files, 1 directories
mifs[9]: Total bytes : 258048
mifs[9]: Bytes used : 8192
mifs[9]: Bytes available : 249856
mifs[9]: mifs fsck took 0 seconds.
mifs[9]: Initialization complete.
mifs[10]: 5 files, 1 directories
mifs[10]: Total bytes : 258048
mifs[10]: Bytes used : 8192
mifs[10]: Bytes available : 249856
mifs[10]: mifs fsck took 0 seconds.
mifs[10]: Initialization complete.
mifs[11]: 649 files, 20 directories
mifs[11]: Total bytes : 122185728
mifs[11]: Bytes used : 51996160
mifs[11]: Bytes available : 70189568
mifs[11]: mifs fsck took 0 seconds.
mifs[11]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not needed(v)
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Passed
extracting front_end/front_end_ucode_info (43 bytes)
Waiting for Stack Master Election...
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Passed
POST: Thermal Tests : Begin
POST: Thermal Tests : End, Status Passed
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
POST: EMAC Loopback Tests : Begin
POST: EMAC Loopback Tests : MAC Loopback Passed
POST: EMAC Loopback Tests : PHY Loopback Passed
POST: EMAC Loopback Tests : End, Status Passed
Election Complete
Switch 1 booting as Master
Waiting for Port download...Complete
Initializing Port Extension Feature Support...
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960XR-24PS-I (APM86XXX) processor (revision S0) with 524288K bytes of memory.
Processor board ID FDO2121B0GP
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : A0:F8:49:53:FD:00
Motherboard assembly number : 73-100640-04
Power supply part number : 341-0531-03
Motherboard serial number : FDO21202TCJ
Power supply serial number : LIT21112DYN
Model revision number : S0
Motherboard revision number : A0
Model number : WS-C2960XR-24PS-I
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FDO2120289F
System serial number : FDO2121B0GP
Top Assembly Part Number : 68-100316-03
Top Assembly Revision Number : D0
Version ID : V06
CLEI Code Number : CMMKN10ARE
Daughterboard revision number : B0
Hardware Board Revision Number : 0x22
Switch Ports Model SW Version SW Image
* 1 28 WS-C2960XR-24PS-I 15.2(4)E6 C2960X-UNIVERSALK9-M
Press RETURN to get started!
*Mar 1 00:00:39.478: Read env variable - LICENSE_BOOT_LEVEL =
*Jan 2 00:00:00.150: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960xr_iplite Next reboot level = iplite and License = iplite
Jan 1 00:00:00.097: in Switch 0. Cannot read pid from Flexstack module
Jan 1 00:00:32.338: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack
Jan 1 00:00:33.736: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Jan 1 00:00:33.736: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
Jan 1 00:00:33.802: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
Jan 1 00:00:35.875: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
Jan 1 00:00:57.612: %PLATFORM_ENV-6-FRU_PS_OIR: FRU Power Supply 1 inserted
Jan 1 00:00:57.682: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
Jan 1 00:00:57.682: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
Jan 1 00:00:57.682: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
Jan 1 00:00:58.122: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
Jan 1 00:00:58.126: %SYS-5-RESTART: System restarted --
Jan 1 00:01:00.090: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to down
Jan 1 00:01:01.093: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
Jan 1 00:01:01.953: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.
--- System Configuration Dialog ---
Enable secret warning
In order to access the device manager, an enable secret is required
If you enter the initial configuration dialog, you will be prompted for the enable secret
If you choose not to enter the intial configuration dialog, or if you exit setup without setting the enable secret,
please set an enable secret using the following CLI in configuration mode-
enable secret 0 <cleartext password>
Would you like to enter the initial configuration dialog? [yes/no]: n
Switch>e
Jan 1 00:01:39.216: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
Jan 1 00:01:39.216: %LINK-5-CHANGED: Interface FastEthernet0, changed state to administratively down
% Ambiguous command: "e"
Switch>en
Jan 1 00:01:41.439: SMI Director is not configured, disabling SMI
Jan 1 00:01:41.439: disable_smartinstall_operation:Disabling SMI
Switch#en
Switch#
Switch#
Switch#
Leo Laohoo
I know what this is.
Do the following to disable SmartInstall (aka ZeroTouch):
conf t
 no vstack
end
wr
Reza Sharifi
The error is related to auto smart and does not appear to be harmful to the switch. Also, there is workaround suggested. Can you try that?
Workaround:
Disable the Smart Install feature manually using the no vstack configuration command immediately after initial installation, if this
feature is not used in your network.
Leo Laohoo
conf t
 no vstack
end
wr
