ISR 4331 inter-chassis high availability
jay3
Hi Friends,
I need assistance with understanding and setting up inter-chassis high availability.I have two routers that I want to set-up in active/standby and I came across that technology in my research.The two routers I want to set-up will be located at the WAN edge and will be used to inter-connect my branches using dynamic routing.Thanks in advance
there are certain restrictions and prerequisites with regard to inter-chassis HA, other than that, the configuration is fairly straight forward.
I am not sure how far you have gotten in your research, but the link below has step by step configuration details...
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/xe-3s/nat-xe-3s-book/iadnat-stateful-int-chass.html
Joseph W. Doherty
What Georg describes might be more than you're asking about. You're just asking a how to use a FHRP (e.g. HSRP) with dynamic routing?
