ISSUE ISR4331
netengL
Every day there is a rapid drop in my connection, this is not all the time, but it happens a few times a day,
It disconnects my connection that I have between my Router01 and my SW1, generating an alarm,
within the company it is only noticed when you are doing tasks where there is a lot of network traffic,
because usually the fall lasts about two 3 seconds and returns to normal.
It shows the message below
*Feb 3 18:12:56.305: %LINK-3-UPDOWN: GigabitEthernet0/0/1 Interface, changed state to down
*Feb 3 18:12:56.421: %IOSXE_INFRA-3-PUNT_ADDR_RES_ENCAP_ERR: Punted address resolution packet with unknown encap UNKNOWN
*Feb 3 18:13:00.302: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/1, changed state to down
*Feb 3 18:13:04.300: %LINK-3-UPDOWN: GigabitEthernet0/0/1 Interface, changed state to up
*Feb 3 18:13:05.301: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/1, changed state to up
*Feb 3 18:13:22.307: %LINK-3-UPDOWN: GigabitEthernet0/0/1 Interface, changed state to down
*Feb 3 18:13:25.304: %LINK-3-UPDOWN: GigabitEthernet0/0/1 Interface, changed state to u
5 Replies 5
there is a bug, not sure if this is related, and if you have LISP/VASI configured...
%IOSXE_INFRA-3-PUNT_ADDR_RES_ENCAP_ERR: seen repeatedly in LISP coworking with VASI
CSCvv33349
Symptom:
The following messages are seen repeatedly.
*Aug 11 17:43:12 JST: %IOSXE_INFRA-3-PUNT_ADDR_RES_ENCAP_ERR: Punted address resolution packet with unknown encap UNKNOWN
*Aug 11 17:44:40 JST: %IOSXE_INFRA-3-PUNT_ADDR_RES_ENCAP_ERR: Punted address resolution packet with unknown encap UNKNOWN
*Aug 11 17:45:41 JST: %IOSXE_INFRA-3-PUNT_ADDR_RES_ENCAP_ERR: Punted address resolution packet with unknown encap UNKNOWN
Conditions:
lisp coworking with vasi interface
Workaround:
use static map cache instead of send-map-request
I do not have a LISP/VASI configured on my network.
in this case it's a trunk between my router and my sw1 only, then it's filling up with logs because alarms come in all the time
also post the full running configs of both your router and your switch...
Leo Laohoo
Post the complete output (minus the IP address) of the following commands:
  1. sh version
  2. sh interface Gi0/0/1
Sure, I can do this.
sh version
Cisco IOS XE Software, Version 17.03.01a
Cisco IOS Software [Amsterdam], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.3.1a, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Wed 12-Aug-20 00:01 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2020 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 16.12(2r)
FL-3443-RT01 uptime is 4 days, 1 hour, 49 minutes
Uptime for this control processor is 4 days, 1 hour, 50 minutes
System returned to ROM by PowerOn
System image file is "bootflash:packages.conf"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 appxk9 RightToUse appxk9
uck9 uck9 RightToUse uck9
securityk9 securityk9 RightToUse securityk9
ipbase ipbasek9 Permanent ipbasek9
The current throughput level is unthrottled
Smart Licensing Status: Smart Licensing is DISABLED
cisco ISR4331/K9 (1RU) processor with 1715479K/3071K bytes of memory.
Processor board ID FLM20XXW08D
Router operating mode: Controller-Managed
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3223551K bytes of flash memory at bootflash:.
SH INTERFACE 01
GigabitEthernet0/0/1 is up, line protocol is up
Hardware is ISR4331-3x1GE, address is 0XX8.8b40.28f1 (bia 0XX8.8b40.28f1)
MTU 1504 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 2/255, rxload 7/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive not supported
Full Duplex, 1000Mbps, link type is auto, media type is RJ45
output flow-control is off, input flow-control is off
ARP type: ARPA, ARP Timeout 00:20:00
Last input 00:00:00, output 00:00:01, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 27457000 bits/sec, 3038 packets/sec
30 second output rate 10183000 bits/sec, 2002 packets/sec
722498259 packets input, 596018868601 bytes, 0 no buffer
Received 2302586 broadcasts (0 IP multicasts)
24 input errors, 0 CRC, 0 frame, 24 overrun, 0 ignored
0 watchdog, 3941011 multicast, 0 pause input
792134463 packets output, 746349386234 bytes, 0 underruns
Output 219338 broadcasts (0 IP multicasts)
0 output errors, 0 collisions, 1 interface resets
290 unknown protocol drops
108 lost carrier, 0 no carrier, 0 pause output
