SSH Weak Key Exchange Algorithms Enabled on WS-C3850-12s
Hello All,
How can i disable this vulnerability: The remote SSH server is configured to allow weak key exchange algorithms on cisco C3850-12s
any help is more than appreciated!
balaji.bandi
what vulnerability ? do you have some logs or information ?
suggest to go with ssh v2
post some information what is running on the device :
show version
show ip ssh
BB
#show ip ssh
SSH Enabled - version 2.0
Authentication methods:publickey,keyboard-interactive,password
Authentication Publickey Algorithms:x509v3-ssh-rsa,ssh-rsa
Hostkey Algorithms:x509v3-ssh-rsa,ssh-rsa
Encryption Algorithms:aes128-ctr,aes192-ctr,aes256-ctr
MAC Algorithms:hmac-sha2-256,hmac-sha2-512,hmac-sha1,hmac-sha1-96
KEX Algorithms:diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1
Authentication timeout: 120 secs; Authentication retries: 3Minimum expected Diffie Hellman key size : 2048 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded): TP-self-signed-265129979
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgQDDeWgXXMoJVWhUjCciXEKAqoFSCp2Msfdc00t/qF82
PTju5BuLhAjyomJOhcgOst9KpbXHq6WR1eAFo+jS3NM9pME9VNd5uwtR7ZnehEewkNt8pTBSDO3ib0nk
RynT+8RYfvMesT/EOpHuWVgQmfhnxyCfgwQ+qaivNbm+m4QFbQ==
#show Version: Cisco IOS XE Software, Version 16.12.05b
Cisco IOS Software [Gibraltar], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.12.5b, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Thu 25-Mar-21 13:09 by mcpre
as you can see above . my device is running already SSH V2
The remote SSH server is configured to allow weak key exchange algorithms.
https://vscan.secintel.ibm.com/vscan/refs/refs.php?vuln_id=491043
Jitendra Kumar
#/etc/ssh/sshd_config
#man sshd_config
copy Ciphers on the notepad and put it into the single line saprated by comma.
Copy MACs also on the notepad and put it also into to the singal line seprated by comma.
then edit file using below command
#vi /etc/ssh/sshd_config
Search Cipher and copy Cipher and MACs and past it into end line of cipher.
Save file
#systemctl restart sshd
thanks,
Jitendra
Jitendra
