Issue trying to convert Bundle Mode to Install Mode
gilesitis
Edit: I was able to figure this one out thanks to another forum post.
The solution is to use the request platform software package install command
Hello everyone,
I'm working with a new stack of 3650s and I wanted to install a newer IOSXE 16.x on the master and then enable auto-upgrade so the other members can get the same IOSXE. Upon trying to install the newer image to the master, the system didn't have enough flash space to install it. I deleted the existing IOS and perhaps in the process deleted some necessary files I shouldn't have (not sure). Eventually I pointed the boot variable to the new .bin file and it worked, but it changed back to Bundle Mode.
Now I am trying to convert back to install mode with the command (exec mode) software expand running to flash
Unfortunately I no longer have the software command available to me.
Is there another way to access the convert method, or have I inadvertently deleted a file that enables the software command?
Just looking for any help at this point to get back on track. Thank you all.
Here are the current contents of flash:
Switch#show flash:
-#- --length-- ---------date/time--------- path
  2    2097152 Jan 31 2022 19:45:07.0000000000 +00:00 nvram_config
  3  480018036 Jan 13 2022 19:23:42.0000000000 +00:00 cat3k_caa-universalk9.16.12.05b.SPA.bin
  4       4096 Feb 01 2022 13:01:44.0000000000 +00:00 .installer
  5         50 Jan 31 2022 19:40:12.0000000000 +00:00 .installer/last_pkgconf_shasum
  6       4096 Jan 31 2022 19:40:35.0000000000 +00:00 .installer/issu_crash
  7       4096 Jan 31 2022 19:42:58.0000000000 +00:00 core
  8       4096 Jan 31 2022 19:40:25.0000000000 +00:00 core/modules
  9          1 Feb 01 2022 13:13:09.0000000000 +00:00 core/.callhome
 10       4096 Jan 31 2022 19:43:02.0000000000 +00:00 onep
 11       4096 Jan 31 2022 19:43:02.0000000000 +00:00 onep/apps-cli
 12   20095616 Jan 31 2022 19:04:01.0000000000 +00:00 cat3k_caa-guestshell.16.12.05b.SPA.pkg
 13   32798679 Jan 31 2022 19:04:02.0000000000 +00:00 cat3k_caa-rpbase.16.12.05b.SPA.pkg
 14  400747128 Jan 31 2022 19:04:22.0000000000 +00:00 cat3k_caa-rpcore.16.12.05b.SPA.pkg
 15         37 Jan 31 2022 19:40:17.0000000000 +00:00 bootloader_evt_handle.log
 16       4096 Jan 31 2022 19:40:31.0000000000 +00:00 dc_profile_dir
 17     241602 Jan 31 2022 19:40:31.0000000000 +00:00 dc_profile_dir/dc_default_profiles.txt
 18     183714 Jan 31 2022 19:00:13.0000000000 +00:00 dc_profile_dir/dc_default_profiles.txt.bkp
 19     337525 Jan 31 2022 19:40:31.0000000000 +00:00 dc_profile_dir/dc_embedded_profiles.txt
 20     337525 Jan 31 2022 19:40:31.0000000000 +00:00 dc_profile_dir/dc_embedded_profiles.txt.bkp
 21    3359360 Jan 31 2022 19:04:22.0000000000 +00:00 cat3k_caa-srdriver.16.12.05b.SPA.pkg
 22   23011964 Jan 31 2022 19:04:25.0000000000 +00:00 cat3k_caa-webui.16.12.05b.SPA.pkg
 23       4096 Jan 31 2022 19:40:31.0000000000 +00:00 .prst_sync
 24        331 Jan 31 2022 19:40:31.0000000000 +00:00 .prst_sync/log
 25         37 Jan 31 2022 19:43:00.0000000000 +00:00 .prst_sync/reload_history
 26       4096 Jan 31 2022 19:40:27.0000000000 +00:00 .rollback_timer
 27       4096 Jan 31 2022 19:40:31.0000000000 +00:00 gs_script
 28       4096 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support
 29      15305 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/igmp-snooping.tcl
 30       1612 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/igmpsn_dump.tcl
 31      13515 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/mld-snooping.tcl
 32       1612 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/mldsn_dump.tcl
 33      15241 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/multicast.tcl
 34       6284 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/multicast_dump.tcl
 35       6718 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/multicast_ipv6.tcl
 36       1365 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/platform-fabric-iid-ethernet.tcl
 37       2107 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/platform-fabric-iid-ipv4.tcl
 38       2109 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/platform-fabric-iid-ipv6.tcl
 39       2729 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/platform-fabric-vrf-ipv4.tcl
 40       2757 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/platform-fabric-vrf-ipv6.tcl
 41      52402 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/platform-fabric-vrf-source.tcl
 42        612 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/platform-fabric.tcl
 43       1548 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/platform_evpn_vxlan.tcl
 44      21852 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/port.tcl
 45       3270 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/port_dump.tcl
 46       7317 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/port_utils.tcl
 47      15655 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/stack.tcl
 48       4938 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/stackwise-virtual.tcl
 49      38541 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/unicast.tcl
 50      12653 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/unicast_dump.tcl
 51       5162 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/unicast_ipv6.tcl
 52       2864 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/unicast_ipv6_dump.tcl
 53        336 Jan 31 2022 19:40:31.0000000000 +00:00 tech_support/utils.tcl
 54     132108 Jan 31 2022 19:40:53.0000000000 +00:00 memleak.tcl
 55         66 Jan 31 2022 19:40:52.0000000000 +00:00 boothelper.log
 56       4096 Jan 31 2022 19:45:08.0000000000 +00:00 .dbpersist
 57       4096 Jan 31 2022 19:45:08.0000000000 +00:00 .dbpersist/DMI_STATE_DB
 58      14942 Jan 31 2022 19:45:08.0000000000 +00:00 .dbpersist/DMI_STATE_DB/DMI_STATE_DB
 59         86 Jan 31 2022 19:45:08.0000000000 +00:00 .dbpersist/DMI_STATE_DB/DMI_STATE_DB.meta
 60        110 Jan 31 2022 19:45:08.0000000000 +00:00 .dbpersist/stats
 61          0 Jan 31 2022 19:42:41.0000000000 +00:00 rdope_out.txt
 62   43021636 Sep 21 2018 14:38:12.0000000000 +00:00 cat3k_caa-iosd-universalk9.SPA.152-2.E4.pkg
 63        545 Jan 31 2022 19:42:53.0000000000 +00:00 rdope.log
 64    2097152 Jan 31 2022 19:45:07.0000000000 +00:00 nvram_config_bkup
 65  111180608 Sep 21 2018 14:38:12.0000000000 +00:00 cat3k_caa-wcm.SPA.10.2.140.0.pkg
417918976 bytes available (1123684352 bytes used)
6 Replies 6
Thank you, that is very helpful!
Leo Laohoo
Yes it is.   The file is there.
The flash simply needs to be "cleaned" first before the Install Mode could begin.
WARNING:  If this switch is going to be in a STACK, AVOID using 16.12.X.
Hi, thanks for the info.
Why do you recommend avoiding 16.12.X for a stack?
because lot of bugs and user experience is bad on those version.
BB
3.6.X, 16.3.X, 16.6.X is a start.
If you need features, 16.9.X.
