L2 etherchannel + inter vlan routing issue
Istvan kelemen
Hello Guys!
Etherchannel is configured between SW1 and SW2. The ports are g1/1 and g1/2 both are trunkporst of course and member of channel-group 1.
If i unplug any wire the connection will never establis again. (Can't ping to SW2 vlan 100 or 101 from SW1 vlan 100 or 101 however the leds are green)
Without etherchannel, (with R-STP) it just works fine, the connection recovers whitin 0,1 sec.
I've tested it in GSN3 too with C2691's routers. (one as router 2 as switch using NM-SW16's)
Sorry about not having a real cisco EQ, i'm learning CCNA.
Reza Sharifi
I don't know how good this will work on GNS, but if you are using reall switches and Etherchannel is configured correctly and you run a continues ping from one a PC in vlan 100 to another PC in vlan 101, and you disconnect one of the links on the Etherchannle, the max ping you should lose is about 3 and the other link should take over and forward traffic.
Can you post the Etherchannel configs from both switches?
Here you go!
SW 1
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
spanning-tree mode rapid-pvst
interface FastEthernet0/1
switchport access vlan 100
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 101
interface FastEthernet0/4
interface FastEthernet0/24
switchport mode trunk
interface GigabitEthernet1/1
channel-group 1 mode on
spanning-tree portfast
interface GigabitEthernet1/2
interface Port-channel 1
SW2
version 12.2
hostname Switch
SW 1
Switch#sh interfaces etherchannel
GigabitEthernet1/1:
Port state          = 1
Channel group          = 1         Mode = On       Gcchange = -
Port-channel  = Po1       GC = -          Pseudo port-channel = Po1
Port index    = 0         Load = 0x0      Protocol = -
Age of the port in the current state:  00d:00h:01m:45s
GigabitEthernet1/2:
Port state          = 1
Port-channel1:Port-channel1
Age of the Port-channel   = 00d:00h:02m:18s
Logical slot/port   = 2/1             Number of ports = 2
GC                  = 0x00000000      HotStandBy port = null
Port state          =
Protocol            =   3
Port Security       = Disabled
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     00     Gig1/1   On                 0
  0     00     Gig1/2   On                 0
Time since last port bundled:    00d:00h:01m:45s    Gig1/2
SW 2
GigabitEthernet1/1:
Port state          = 1
Age of the port in the current state:  00d:00h:02m:00s
GigabitEthernet1/2:
Port state          = 1
Age of the Port-channel   = 00d:00h:02m:16s
Port state          =
Protocol            =   3
  0     00     Gig1/1   On                 0
  0     00     Gig1/2   On                 0
Time since last port bundled:    00d:00h:02m:00s    Gig1/2
Hi Istvan,
Looks like you dont have consistent etherchannel configuration. Dont enable the portfast on trunk links. Modify the configurations as below.
SW 1
speed 1000
duplex full
shut
speed 1000
duplex full
shut
SW2
speed 1000
duplex full
shut
speed 1000
duplex full
shut
Once the port channel interface are configured give no shut on the physcial interface and verify if the ehther channels are formed. If yes then try your failover test.
Being said above this may not work as expected on a GNS3/PT environment. The best way to check this when you shutdown the one port of SW1 verify the other end of port (SW2) is showing as down. If not the simulated switch is not cabaple of  detecting the physical link failure and keeps on forwarding traffic on that interface. Those are the limitations of a simulated environment.
Hope that helps.
Najaf
glen.grant
  Try changing the connecting ports to " channel-group 1 mode desirable non-silent"  and see if it changes anything.
