L2 Switch to L3 Switch
jasongr33nway
I have two 3850s (Stacked) at our DR site. Everything is working fine from our OPS site to our DR site. There are a few more devices we need to add to our DR site and our 3850s are out of INTs. I visited yesterday and trunked a L2 (2960-s) switch to one of the 3850s. My issue is, I cannot pass any traffic from the L2 switch to any of the SVIs on the 3850 unless I create and SVI on the L2 switch for each SVI on the 3850. I thought I would be able to trunk the L2, add vlans and pass traffic over the trunk without creating SVIs on the L2 switch.
3850:
interface Vlan1
 no ip address
 shutdown
interface Vlan7
 description DR-Hotsite vlan
 ip address 10.7.254.1 255.255.0.0
 ip helper-address 10.6.240.11
 no ip proxy-arp
interface Vlan12
 description dr-voice-vlan
 ip address 10.12.254.1 255.255.0.0
 no ip proxy-arp
interface Vlan57
 description SJ RPA-WAN Vlan 57
 ip address 10.5.7.254 255.255.255.0
 no ip proxy-arp
interface Vlan108
 description DR ISCSI Vlan 108
 ip address 10.108.254.1 255.255.0.0
 no ip proxy-arp
interface Vlan109
 description DR ISCSI Vlan 109
 ip address 10.109.254.1 255.255.0.0
 no ip proxy-arp
interface Vlan252
 description L2_MANAGEMENT_INT
 ip address 10.8.252.1 255.255.255.0
interface Vlan614
 ip address 172.16.188.2 255.255.255.252
 no ip proxy-arp
C3850-STACK-DR-M0-1#sh int gi 2/0/23 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
C3850-STACK-DR-M0-1#sh int trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi1/0/14    on               802.1q         trunking      1
Gi1/0/18    on               802.1q         trunking      1
Gi1/0/20    on               802.1q         trunking      1
Gi2/0/19    on               802.1q         trunking      1
Gi2/0/23    on               802.1q         trunking      1
Po1         on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi1/0/14    614
Gi1/0/18    7,12
Gi1/0/20    7,12,800
Gi2/0/19    7,12,800
Gi2/0/23    1-4094
Po1         7,12,800
Port        Vlans allowed and active in management domain
Gi1/0/14    614
Gi1/0/18    7,12
Gi1/0/20    7,12,800
Gi2/0/19    7,12,800
Gi2/0/23    1,7,10,12,57,108-109,614,800,900
Po1         7,12,800
Port        Vlans in spanning tree forwarding state and not pruned
Gi1/0/14    614
Gi1/0/18    7,12
Gi1/0/20    7,12,800
Gi2/0/19    7,12,800
Po1         7,12,800
2960:
DR_2960-S(config)#do sh int gi 1/0/47 switchport
Switchport: Enabled
Voice VLAN: none
Protected: false
DR_2960-S#sh int trunk
Gi1/0/47    on               802.1q         trunking      1
Gi1/0/47    1-4094
Gi1/0/47    1,7,10,12,57,108-109,252,614,800,900
2 Accepted Solutions
Rather than using 10.7.254.4 as your default gateway (unsure what this device is), can you try using 10.7.254.1 (your 3850).
Interesting. Can you verify packets are being sourced from 10.7.254.252 on the 2960 and try again? What does "show ip route" look like from the other side of MPLS?
22 Replies 22
Reza Sharifi
You should not need any IP (SVI) on the layer-2 switch (2960). Just a trunk port from 2960 to the 3850 with all vlans included should be sufficient.  The only IP (SVI) you need on the layer-2 switch is a management IP so, you can reach the device. The output you posted looks all correct.
Can you post the output of "sh run int g2/0/3" and "sh run int  g1/0/47"
Also, do you have a test device connected to a port on the 2960 and is the vlan configured on that port?
Reza,
Thanks for the response. That is exactly what I thought but, I am unable to ping any of the SVIs from the L2 switch unless I add an SVI to the L2 switch.
Im going to assume you meant gi 2/0/23
C3850-STACK-DR-M0-1#sh run int gi 2/0/23
Building configuration...
Current configuration : 154 bytes
interface GigabitEthernet2/0/23
 description TX-AlertLogic-IDS-2 MANAGEMENT
 switchport mode trunk
 switchport nonegotiate
 spanning-tree portfast
end
DR_2960-S#sh run int gi 1/0/47
Current configuration : 119 bytes
interface GigabitEthernet1/0/47
 description TRUNK_TO_3750_STACK
end
Sorry, that is correct.
What vlan and IP is the end device you are testing with in?
not that this matter in this case, but you don't need  "spanning-tree portfast" on a trunk port.
Can you also remove  "switchport nonegotiate" from both sides and try again?
DR_2960-S(config)#no int vlan 12
DR_2960-S(config)#^Z
DR_2960-S#
DR_2960-S#ping
Protocol [ip]:
Target IP address: 10.12.254.1
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 10.7.254.252
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 10.12.254.1, timeout is 2 seconds:
Packet sent with a source address of 10.7.254.252
Success rate is 0 percent (0/5)
DR_2960-S#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
DR_2960-S(config)#int vlan 12
DR_2960-S(config-if)#ip address 10.12.254.252 255.255.0.0
DR_2960-S(config-if)#do pin
Protocol [ip]:
Repeat count [5]:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/204/1001 ms
BradEast1
Level 3
Level 3
Do you have a default gateway or default route set on the 2960?
Yes, I can ping internet IPs. I just can't pass any traffic to our internal network. None of the SVIs on the 3850 unless I add that SVI to the 2960 and no access across our MPLS network via the 2960 but, the 3850 has no issue going across our MPLS network.
Could you post the entire "show run" output from the 2960?
DR_2960-S#sh run
Current configuration : 5013 bytes
version 15.0
no service pad
hostname DR_2960-S
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c2960s-48fps-l
ip domain-name
crypto pki trustpoint TP-self-signed-1919529216
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1919529216
 revocation-check none
 rsakeypair TP-self-signed-1919529216
crypto pki certificate chain TP-self-signed-1919529216
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31393139 35323932 3136301E 170D3131 30333330 30313239
  35365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 39313935
  32393231 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C317 876BCF92 C65915A2 48E1C438 680D815A AA0887B8 3B9232DC 5A7B169C
  36180ACF A690ADD6 BA10A7DB 48E652A7 DEE3859A DFA993C6 847E0CEA C52CD8BB
  0591CBA4 28B7FB72 2AB6198E A0C5D109 975AEA46 4CB91472 E3D3B8C0 F2339F27
  ABE021ED 205124BE 6D29E4A3 C68751A8 6151E3E8 518E2D19 92129F39 30502CCA
  4B310203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14B44C65 1F884BC2 550BDABB 7444461E 7AA53ECD 21301D06
  03551D0E 04160414 B44C651F 884BC255 0BDABB74 44461E7A A53ECD21 300D0609
  2A864886 F70D0101 05050003 818100BF 71A08880 E95754C2 68CEBF9B FBE9426F
  2EA81744 EBC1B158 C6362EAD 7863DC3D 4D8FA436 F8918E55 1E3B5ABA B75E2E4C
  8116275D 353ABDAE EDC5504E 7082A3FB 526C12E3 B8DA7C60 909FC412 26069969
  2E08891C 4C737DAA F39255D5 8BF9543E E1B618EB EE2EE7C4 B9ABF234 7E3EC9BD
  2A97B79A CEDD134D 52F3B7FB DAFBB0
        quit
spanning-tree mode rapid-pvst
spanning-tree vlan 1,7,10,12,57,108-109,614,800,900 priority 36864
vlan internal allocation policy ascending
interface FastEthernet0
 no ip address
interface GigabitEthernet1/0/1
 description ESX-DR2-ILO
 switchport access vlan 7
interface GigabitEthernet1/0/2
 description ESX-DR2-MANAGEMENT
 shutdown
interface GigabitEthernet1/0/3
 description ALERTLOGIC-MANAGEMENT
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
 no ip address
interface Vlan7
 ip address 10.7.254.252 255.255.0.0
interface Vlan12
 description DR_VOICE_VLAN
ip default-gateway 10.7.254.4
ip http server
ip http secure-server
line con 0
 login local
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 login local
 transport input ssh
end
Hey that worked! I can now ping the SVIs on the 3850 however, I am not able to pass traffic over the MPLS.
DR_2960-S#ping 172.16.188.2
Sending 5, 100-byte ICMP Echos to 172.16.188.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 5/7/11 ms
DR_2960-S#ping 172.16.188.1
Sending 5, 100-byte ICMP Echos to 172.16.188.1, timeout is 2 seconds:
Can you ping that address from your 3850 when sourcing packets from 10.7.254.1?
Yes I can.
C3850-STACK-DR-M0-1#ping
Protocol [ip]:
Target IP address: 172.16.188.1
Repeat count [5]:
Source address or interface: 10.7.254.1
Packet sent with a source address of 10.7.254.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/6/10 ms
DR_2960-S#ping
Protocol [ip]:
Repeat count [5]:
DR_2960-S#ping
Protocol [ip]:
Target IP address: 172.16.188.2
Repeat count [5]:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/5/10 ms
From our 4500 stack
B        10.7.0.0/16 [20/0] via 12.x.x.x, 6w3d
 172.16.0.0/30 is subnetted, 1 subnets
B        172.16.188.0 [20/0] via 12.x.x.x, 6w3d
From our 3850 stack
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.16.188.0/30 is directly connected, Vlan614
L        172.16.188.2/32 is directly connected, Vlan614
