09-25-2009 05:54 AM - edited 03-06-2019 07:53 AM
I am trying to configure LACP between our Cisco 3750 stack and an EMC SAN.
I have 2 GigabitEthernet ports that I have put into port-channel 20, please see the below config for the 2 interfacesâ¦
interface GigabitEthernet2/0/10
description EMC
switchport trunk native vlan 101
switchport mode trunk
speed 1000
duplex full
channel-protocol lacp
channel-group 20 mode active
interface GigabitEthernet2/0/12
description EMC
speed 1000
duplex full
When using the above configuration the links do not come up, the port-channel interface and 2 physical interfaces show as notconnect.
However, when I switch the mode to 'on' (therfore not use a protocol) the etherchannel comes up no problem.
I have been assured that the EMC SAN is configured correctly and is able to use LACP.
I have also tried 'passive' mode with no joy!
Any help is greatly appreciated.
Steve
09-25-2009 06:36 AM
The switch side looks fine , without seeing the san side which is where the problem probably is it's hard speculate. If it works as "on" then maybe the san is set as on also .
09-26-2009 04:00 AM
Hello Steve,
probably the EMC SAN is not sending LACP messages and the switch after a timer expiration puts the ports in a suspended state.
Check the switch log for LACP related messages with
sh log | inc LACP
By the way, this is the advantage of LACP it can detect problems with the neighbor device.
Hope to help
Giuseppe
