LACP neighbor can't establish between 3850 and 2960X
zexinfinite
Hi all,
I've tried to establish LACP neighbor between 3850 and 2960X, but I can't see the LACP relationship come up.
The LACP counter on 3850 is normal, there have send and receive LACPDU, but there have no receive packet on 2960X, even I tried to debug lacp all on 2960X and restart interface on 3850, there still can not receive LACPDU from Gi2/0/49 on 2960X.
I saw there have bug on 3.7.4,and already fixed on 3.7.5.
If it is possible to meet the bug again on these version?
# IOS version on 3850-24XS-E
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.07.05.E RELEASE SOFTWARE (fc1)
#Config on 3850
interface Port-channel8
switchport trunk allowed vlan 123
switchport mode trunk
interface TenGigabitEthernet1/0/8
channel-group 8 mode active
interface TenGigabitEthernet2/0/8
#show lacp counter on 3850
LACPDUs Marker Marker Response LACPDUs
Port Sent Recv Sent Recv Sent Recv Pkts Err
Channel group: 8
Te1/0/8 59 60 0 0 0 0 0
Te2/0/8 226 58 0 0 0 0 0
#IOS version on 2960X-48TS & 2960X-48FPS
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E6, RELEASE SOFTWARE (fc1)
#Config on 2960X
interface Port-channel1
description "To DG5 Distribution switch"
spanning-tree portfast disable
spanning-tree bpdufilter disable
spanning-tree bpduguard disable
spanning-tree guard none
ip dhcp snooping trust
interface GigabitEthernet1/0/49
channel-group 1 mode active
interface GigabitEthernet2/0/49
# show lacp counter on 2960X
Channel group: 1
Gi1/0/49 83 77 0 0 0 0 0
Gi2/0/49 90 0 0 0 0 0 0
Moses Fernandes
Make sure that ALL the port participating in the etherchannel have identical settings.
This includes speed, Vlans, Swichport mode.
You may also run --> sh interface Port-channel XX <--  on both the switches and compare the output.
You may also set the etherchannel to Active-Active and see if that helps..
If you find a post helpfull mark it as help full.
Moses.
Hi Moses,
Thank you for your opinion!
I've tried to reload second 3850 and it's work now.
Julio E. Moisa
Also check the negotiation, speed and duplex the same for both.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
