09-27-2017 06:38 AM - edited 03-08-2019 12:11 PM
We have a port channel with 2 of 1G links between our cores of the datacenter.
Due to the issue with one link, we want to force all traffice to another link, only use the 2nd physical link when the 1st physical link is full.
Is there a way of doing it?
We cannot do with src-dst-mac/ip/port etc, those options are not good for us.
Solved! Go to Solution.
09-27-2017 07:31 AM
You cannot control the port that a particular flow uses. You can only influence the load balance with a frame distribution method that results in the greatest variety.
Note: The hash algorithm cannot be configured or changed to load balance the traffic among the ports in an EtherChannel.
Moses.
09-27-2017 07:31 AM
Moses.
