LACP Nexus 9k Lab on Pnetlab
VuongNguyen2903
Hi everyone,
I practice the Lab on Pnetlab. Connect 2 Nexus and configuration Port channel.
I have issue with the information: I configure Channel Po10 for 2 Nexus on both e1/1 port.
version 9.3(4) Bios:version
interface Ethernet1/1
switchport mode trunk
speed 10000
duplex full
channel-group 10 mode active
switch(config-if)# show run int po10
!Command: show running-config interface port-channel10
!Running configuration last done at: Tue Apr 4 03:17:11 2023
!Time: Tue Apr 4 03:21:57 2023
speed 10000
duplex full
Group Port- Type Protocol Member Ports
Channel
10 Po10(SD) Eth LACP Eth1/1(s)
2023 Apr 4 03:17:13 switch %ETHPORT-5-IF_ADMIN_UP: Interface port-channel10 is
admin up .
2023 Apr 4 03:17:13 switch %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interf
ace port-channel10 is down (No operational members)
2023 Apr 4 03:17:13 switch last message repeated 1 time
2023 Apr 4 03:17:13 switch %ETHPORT-5-SPEED: Interface Ethernet1/1, operational
speed changed to 1 Gbps
2023 Apr 4 03:17:13 switch %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/1, operati
onal duplex mode changed to Full
2023 Apr 4 03:17:13 switch %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/1
, operational Receive Flow Control state changed to off
2023 Apr 4 03:17:13 switch %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/1
, operational Transmit Flow Control state changed to off
2023 Apr 4 03:17:13 switch %ETHPORT-5-SPEED: Interface port-channel10, operatio
nal speed changed to 1 Gbps
2023 Apr 4 03:17:13 switch %ETHPORT-5-IF_DUPLEX: Interface port-channel10, oper
ational duplex mode changed to Full
2023 Apr 4 03:17:13 switch %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channe
l10, operational Receive Flow Control state changed to off
2023 Apr 4 03:17:13 switch %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channe
l10, operational Transmit Flow Control state changed to off
2023 Apr 4 03:17:23 switch %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/1: Eth
ernet1/1 is suspended
You may give me the solution? Thank you for your support.
18 Replies 18
TotallyTodd
You totally need 2 or more interfaces on the same device to create a port-channel totally.
balaji.bandi
that should work as expected on the version you using, (there are some issue on old version 9.3 is good to work)
try below commands (both the switches)
shutdown
no lacp suspend-individual
no shutdown
BB
Tks. I will try to do it.
Totally hope it works!
If I used this command as  above. Interface Po will down: Po100 1 eth trunk down No operational members auto(D) lacp
Po100  - hope this is PO10
I just tested  and works as expected: below test results :
feature lacp
switchport
switchport
no shutdown
BB
VuongNguyen2903
Nexus01:
Interface Ethernet1/1 is suspended
Channel group is 10 port channel is Po10
PDUs sent: 32
PDUs rcvd: 0
Markers sent: 0
Markers rcvd: 0
Marker response sent: 0
Marker response rcvd: 0
Unknown packets rcvd: 0
Illegal packets rcvd: 0
Lag Id: [ [(0, 0-0-0-0-0-0, 0, 0, 0), (0, 0-0-0-0-0-0, 0, 0, 0)] ]
Operational as aggregated link since Thu Jan 1 00:00:00 1970
Nexus02:
PDUs sent: 44
PDUs rcvd: 0
Markers sent: 0
Markers rcvd: 0
Everyone can help me?
The speed duplex is mismatch
Please hardcoded the value and try check again.
Tks for reply.
I have configure on int and po: speed 1000. and 2 device the same configure. But no effect.
check my config above
start from zero do these steps
do this in both NSK in same time i.e. when you config keepalive in NSK1 dont go to step2 but config keepalive in NSK2
1- CONNECT interface that use for keepalive
2- config the keepalive interface
3-
feature vpc
feature lacp
feature inter-vlan
4- config the spanning tree mode mst
config spanning tree mst config
revision 0
instance 0 vlan 1-4094
5-
config the vpc domain
config peer-keepalive and use vrf default in end of this command
6-connect interface that use as vpc peer-link
7- interface ex/x
channel-group 1 mode active  forces
no shut
8- interface port-channel 1
spanning-tree port type network
switchport trunk allow vlan 1,.... <<- what you want other vlan specific here
vpc peer-link
no shut
that all steps you need
the issue is there is bug if you config peer-link before config the SPT MST the peer-link never go UP
Thank you very much,
But I only configure the channel-port in this lab.
You can give me your advice? Please
version 9.3(9) Bios:version
speed 1000
01(config-if)# show run int e1/1
!Command: show running-config interface Ethernet1/1
!Running configuration last done at: Thu Apr 6 02:06:06 2023
!Time: Thu Apr 6 02:06:17 2023
speed 1000
01(config-if)#
speed 1000
02(config-if)# show run int e1/1
!Running configuration last done at: Thu Apr 6 02:05:57 2023
!Time: Thu Apr 6 02:06:31 2023
speed 1000
02(config-if)#
