LACP Nexus 9k Lab on Pnetlab
VuongNguyen2903
Hi everyone,
I practice the Lab on Pnetlab. Connect 2 Nexus and configuration Port channel.
I have issue with the information: I configure Channel Po10 for 2 Nexus on both e1/1 port.
version 9.3(4) Bios:version
interface Ethernet1/1
switchport mode trunk
speed 10000
duplex full
channel-group 10 mode active
switch(config-if)# show run int po10
!Command: show running-config interface port-channel10
!Running configuration last done at: Tue Apr 4 03:17:11 2023
!Time: Tue Apr 4 03:21:57 2023
speed 10000
duplex full
Group Port- Type Protocol Member Ports
Channel
10 Po10(SD) Eth LACP Eth1/1(s)
2023 Apr 4 03:17:13 switch %ETHPORT-5-IF_ADMIN_UP: Interface port-channel10 is
admin up .
2023 Apr 4 03:17:13 switch %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interf
ace port-channel10 is down (No operational members)
2023 Apr 4 03:17:13 switch last message repeated 1 time
2023 Apr 4 03:17:13 switch %ETHPORT-5-SPEED: Interface Ethernet1/1, operational
speed changed to 1 Gbps
2023 Apr 4 03:17:13 switch %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/1, operati
onal duplex mode changed to Full
2023 Apr 4 03:17:13 switch %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/1
, operational Receive Flow Control state changed to off
2023 Apr 4 03:17:13 switch %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/1
, operational Transmit Flow Control state changed to off
2023 Apr 4 03:17:13 switch %ETHPORT-5-SPEED: Interface port-channel10, operatio
nal speed changed to 1 Gbps
2023 Apr 4 03:17:13 switch %ETHPORT-5-IF_DUPLEX: Interface port-channel10, oper
ational duplex mode changed to Full
2023 Apr 4 03:17:13 switch %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channe
l10, operational Receive Flow Control state changed to off
2023 Apr 4 03:17:13 switch %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channe
l10, operational Transmit Flow Control state changed to off
2023 Apr 4 03:17:23 switch %ETH_PORT_CHANNEL-5-PORT_SUSPENDED: Ethernet1/1: Eth
ernet1/1 is suspended
You may give me the solution? Thank you for your support.
18 Replies 18
1-
feature lacp
feature inter-vlan
2- config the spanning tree mode mst
config spanning tree mst config
revision 0
instance 0 vlan 1-4094
3-connect interface that use as po
7- interface ex/x
channel-group 1 mode active  forces
no shut
8- interface port-channel 1
spanning-tree port type network
switchport trunk allow vlan 1,.... <<- what you want other vlan specific here
no shut
VuongNguyen2903
seem the lab is bug. I don't certainly. I have to connect the link before I start device such I can configure port channel to success.
Yes it sure bug' I face the same in my lab exactly same
N9k refused up po' but I found if I config spt mst the issue is solve.
Do show spanning tree you will see that PO and port members is missing from spanning tree table!!
Thank you for your useful information
