lan switching
chpmotry
hi guys.
i have 2 switch 2960x-48ts-l . without any config .i want to use these two switches as hubs. but when i connect One client to one switch and another client to another switch, the clients do not ping each other. I turned off firewall of clients but No changes were made.
config in switch-2960x-1
int g1/0/1
int g1/0/2
int g1/0/3
description connected-to-swicth-2
config in switch-2960x-2
int g1/0/1
int g1/0/2
int g1/0/3
description connected-to-swicth-1
Communication ports are up/up .
Mark Elsen
 - On a switch , you will need a minimum configuration for end nodes to be able to communicate such as :
                              config-if # switchport host
   The ports which are connecting the two switches must be configured as a trunk
 M.
M02@rt37
Hello @chpmotry,
since Switch is more intelligent as Hub, you need a minimum conf on switches, such as Trunk link between them and add the command  @Mark Elsen said. This command 'switchport host' does 3 things:
--Configures the switchport for access mode
--Enables portfast
--Disables Etherchannel
Best regards
simply SW without any config all port assign to VLAN 1,
so these two SW not issue I think
the issue you assign different IP in both PC and hence connect is failed
