Latency between vm hosts in different sites
Hi all,
I am seeing latency on VM hosts between two sites on a dedicated 10gb link. When investigating the network I have also discovered errors on one of the connecting core switches and the other sites distrubtion switch which connects to the VM environment.
Does anybody know what these error are related to?
What is the fix/resolution of the errors?
Could they be causing the latency?
Site A
cdk_xgs_reg_read[3]: Invalid S-channel ACK: 11 (expected 12) addr=0x00580238
54978923: Jan 13 2023 15:48:30.066 gmt: %EARL-SW2_DFC1-1-EXCESSIVE_PARITY_ERROR: EARL 1: Parity error detected in VRAM
15:48:30.910 FW[MOD 17]: radian_monitor_pll:: port_num[20] unit[3] bcmport[5] : PLL reset failed - xlport_xgxs_status_gen_reg = 0x14  xlport_xgxs_ctrl_reg = 0x1619DE78
cdk_xgs_reg_read[3]: Invalid S-channel ACK: 11 (expected 12) addr=0x00580252
cdk_xgs_reg_read[3]: Invalid S-channel ACK: 11 (expected 12) addr=0x00580237
15:48:34.718 FW[MOD 17]: radian_monitor_pll:: port_num[20] unit[3] bcmport[5] : PLL reset failed - xlport_xgxs_status_gen_reg = 0x14  xlport_xgxs_ctrl_reg = 0x1619DE78
54978924: Jan 13 2023 15:48:37.310 gmt: %EARL-SW2_DFC1-1-EXCESSIVE_PARITY_ERROR: EARL 1: Parity error detected in VRAM
54978925: Jan 13 2023 15:48:38.294 gmt: %EARL-SW2_DFC1-1-EXCESSIVE_PARITY_ERROR: EARL 1: Parity error detected in VRAM
15:48:38.966 FW[MOD 17]: radian_monitor_pll:: port_num[20] unit[3] bcmport[5] : PLL reset failed - xlport_xgxs_status_gen_reg = 0x14  xlport_xgxs_ctrl_reg = 0x1619DE78
54978926: Jan 13 2023 15:48:39.318 gmt: %EARL-SW2_DFC1-1-EXCESSIVE_PARITY_ERROR: EARL 1: Parity error detected in VRAM
Site B
2023 Jan 13 16:47:02 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[26709]
2023 Jan 13 16:47:24 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[26837]
2023 Jan 13 16:47:37 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[26919]
2023 Jan 13 16:48:18 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[27042]
2023 Jan 13 16:48:18 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[27044]
2023 Jan 13 16:48:18 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[27047]
2023 Jan 13 16:48:51 GRH-S40-N9K01 %TAHUSD-SLOT1-4-BUFFER_THRESHOLD_EXCEEDED: Module 1 Instance 0 Pool-group buffer 90 percent threshold is exceeded!
2023 Jan 13 16:50:51 GRH-S40-N9K01 %TAHUSD-SLOT1-4-BUFFER_THRESHOLD_EXCEEDED: Module 1 Instance 0 Pool-group buffer 90 percent threshold is exceeded! (message repeated 1 time)
2023 Jan 13 16:50:59 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: kex_exchange_identification: write: Broken pipe - dcos_sshd[28823]
2023 Jan 13 16:52:00 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[29346]
2023 Jan 13 16:52:51 GRH-S40-N9K01 %TAHUSD-SLOT1-4-BUFFER_THRESHOLD_EXCEEDED: Module 1 Instance 0 Pool-group buffer 90 percent threshold is exceeded!
2023 Jan 13 16:53:31 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[29653]
2023 Jan 13 16:54:53 GRH-S40-N9K01 %TAHUSD-SLOT1-4-BUFFER_THRESHOLD_EXCEEDED: Module 1 Instance 0 Pool-group buffer 90 percent threshold is exceeded!
2023 Jan 13 16:55:13 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[30494]
2023 Jan 13 16:55:58 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[4478]
2023 Jan 13 16:55:59 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: kex_exchange_identification: write: Broken pipe - dcos_sshd[4539]
2023 Jan 13 16:56:54 GRH-S40-N9K01 %TAHUSD-SLOT1-4-BUFFER_THRESHOLD_EXCEEDED: Module 1 Instance 0 Pool-group buffer 90 percent threshold is exceeded!
2023 Jan 13 16:57:02 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[5627]
2023 Jan 13 16:57:26 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[5730]
2023 Jan 13 16:57:37 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[5821]
2023 Jan 13 16:58:54 GRH-S40-N9K01 %TAHUSD-SLOT1-4-BUFFER_THRESHOLD_EXCEEDED: Module 1 Instance 0 Pool-group buffer 90 percent threshold is exceeded!
2023 Jan 13 17:00:54 GRH-S40-N9K01 %TAHUSD-SLOT1-4-BUFFER_THRESHOLD_EXCEEDED: Module 1 Instance 0 Pool-group buffer 90 percent threshold is exceeded! (message repeated 1 time)
2023 Jan 13 17:00:59 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: kex_exchange_identification: write: Broken pipe - dcos_sshd[6947]
2023 Jan 13 17:01:51 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[7123]
2023 Jan 13 17:02:54 GRH-S40-N9K01 %TAHUSD-SLOT1-4-BUFFER_THRESHOLD_EXCEEDED: Module 1 Instance 0 Pool-group buffer 90 percent threshold is exceeded!
2023 Jan 13 17:04:55 GRH-S40-N9K01 %TAHUSD-SLOT1-4-BUFFER_THRESHOLD_EXCEEDED: Module 1 Instance 0 Pool-group buffer 90 percent threshold is exceeded! (message repeated 1 time)
2023 Jan 13 17:05:10 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[8303]
2023 Jan 13 17:05:58 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[14713]
2023 Jan 13 17:05:59 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: kex_exchange_identification: write: Broken pipe - dcos_sshd[14753]
2023 Jan 13 17:06:55 GRH-S40-N9K01 %TAHUSD-SLOT1-4-BUFFER_THRESHOLD_EXCEEDED: Module 1 Instance 0 Pool-group buffer 90 percent threshold is exceeded!
2023 Jan 13 17:07:02 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[16013]
2023 Jan 13 17:07:22 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[16105]
2023 Jan 13 17:07:37 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[16221]
2023 Jan 13 17:08:55 GRH-S40-N9K01 %TAHUSD-SLOT1-4-BUFFER_THRESHOLD_EXCEEDED: Module 1 Instance 0 Pool-group buffer 90 percent threshold is exceeded!
2023 Jan 13 17:10:55 GRH-S40-N9K01 %TAHUSD-SLOT1-4-BUFFER_THRESHOLD_EXCEEDED: Module 1 Instance 0 Pool-group buffer 90 percent threshold is exceeded! (message repeated 1 time)
2023 Jan 13 17:12:48 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[17691]
2023 Jan 13 17:12:55 GRH-S40-N9K01 %TAHUSD-SLOT1-4-BUFFER_THRESHOLD_EXCEEDED: Module 1 Instance 0 Pool-group buffer 90 percent threshold is exceeded!
2023 Jan 13 17:14:56 GRH-S40-N9K01 %TAHUSD-SLOT1-4-BUFFER_THRESHOLD_EXCEEDED: Module 1 Instance 0 Pool-group buffer 90 percent threshold is exceeded! (message repeated 1 time)
2023 Jan 13 17:15:10 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[18195]
2023 Jan 13 17:15:58 GRH-S40-N9K01 %DAEMON-3-SYSTEM_MSG: error: protocol identification string lack carriage return - dcos_sshd[18801]
Thank you
marce1000
 - For the Cisco switches involves , what models are you using ?
 M.
