Intermittent connectivity issues while connecting cameras on Cisco 2960 series switch
Hi all,
   I have Cisco 2960 series switch, I am connecting cameras on LAN post.
Some cameras working fine, but some cameras showing intermettant connectivity
Issue-
if I shut and no shut switch port, it takes IP for 5-10 sec only,  after it shows APIPA  address,
luis_cordova
Hi @davariganesh1994 ,
I leave you a couple of links. The first is a guide to problems with dhcp and the second of a discussion about a bug reported:
https://www.cisco.com/c/en/us/support/docs/ip/dynamic-address-allocation-resolution/27470-100.html
https://community.cisco.com/t5/switching/2960x-intermittent-connectivity-issues/m-p/3228391
I hope that they are useful for you
Deepak Kumar
May I ask a few questions:
1.  What is port configuration and any logs generated related to STP or POE?
2. What are the firmware version and POE budge?
3. Have you tried with POE injector? is reported issue repeated with POE injector?
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
in addition to the other posts, what is the type/brand/model of the IP cameras ?
ivanflash84
I'm sorry for bringing up this post from the dead, but i had a same problem with Sanyo cameras last week and with c2960S-48FPD-L PoE. I solved it with a "new" IOS.
BR, Ivan
