Latency test between end points
ruud.manders
Visitor
Hi all,
We have the following design:
server-1gbs-4500-10gbs-6500-10gbs-6500-10gbs-4500-1gbs-SAN
Is there a way to test the latency between these two end points?
Is there a document that says howmuch latency there can be?
Thnx in advance.
regards
Ruud
m.brentlinger
Community Member
im not sure i understand the question. are you asking how to interject and test varying latencies or asking just based on the connection types what theoretical latency should be vs comparing that to actual latency
i would like to know this:
based on the connection types what theoretical latency should be vs comparing that to actual latency.
shiva_ial
Level 4
Level 4
configuring ip sla would be a right one
With IP SLA, can i guaranty a delay of maximum 6ms?
