layer 3 etherchannel issue
sarahr202
Level 7
Level 7
Hi everybody
I am trying to perform a lab on etherchannel
host1----  >  Layer 2 switch----ethetchannel----R1
host 2---- >
On switch site, we want f1/1-3 to be in layer2 port channel 1 and on router site, we want f0/0,0/1 f1/0 be in layer 3 port channel 1
I am able to configure etherchannel on switch site as shown below:
sw#show etherchannel summary
Flags:  D - down        P - in port-channel
        I - stand-alone s - suspended
        R - Layer3      S - Layer2
        U - in use
Group Port-channel  Ports
1    Po1(SU)    Fa1/1(P)  Fa1/2(P)  Fa1/3(P)
However iam unable to  configure the etherchannel on router site:
R1#show etherchannel summary
        U - in use
R1 running -config:
R1#show running-config
Building configuration...
Current configuration : 1105 bytes
version 12.4
hostname R1
ip cef
interface Port-channel1
ip address 199.199.199.10 255.255.255.0
full-duplex
hold-queue 225 in
interface FastEthernet0/0
no ip address
duplex auto
speed auto
channel-group 1
interface FastEthernet0/1
no ip address
duplex auto
speed auto
channel-group 1
interface FastEthernet1/0
no ip address
duplex auto
speed auto
channel-group 1
ip forward-protocol nd
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
Sw config :
sw#show running-config
Current configuration : 1547 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
duplex full
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/1
duplex full
channel-group 1 mode on
interface FastEthernet1/2
duplex full
interface FastEthernet1/3
duplex full
interface Vlan1
no ip address
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
I appreciate your help.
Thanks and have a great day
2 Accepted Solutions
Reza Sharifi
Hi Sarah,
A portchannel can be a layer-2 portchannel or a layer-3 portchannel and not a combination of both.  In your config the switch is just a layer-2 po and on the router is layer-3.
So, since you are connecting to a router, I assume you want a later-3 po.  In that case under the po interface add an IP address on the same segment as the router side.
sw
ip address 199.199.199.11 255.255.255.0
Reza
Hello Reza,
This depends on what you exactly have in mind. You can do a combination of both if you pay attention how the L3 segment is terminated on both devices. Let's move EtherChannels aside for a moment and consider the following configuration:
Router:
ip address 192.0.2.1 255.255.255.0
no shutdown
Switch:
switchport mode access
switchport access vlan 5
interface Vlan5
ip address 192.0.2.2 255.255.255.0
This configuration will run just fine - the router would have a working IP connectivity with the switch. Now, we do this:
Router:
channel-group 1
no shutdown !
channel-group 1
no shutdown
Switch:
channnel-group 1 mode on
interface FastEthernet0/2
switchport access vlan 5 !
interface Vlan5
This should work as well because instead of a single Ethernet link between these devices, we now are using EtherChannel which is a transparent technology to the applications that are using it. You are of course absolutely correct that if there is an L3 connectivity assumed over this EtherChannel then the IP addresses must be configured somewhere. In case of an L3 EtherChannel, it would be the Port-channel interface itself. In case of L2 EtherChannel, the IP address would be associated on the appropriate SVI.
Sarah, I believe that the router provides you with an empty output in the show etherchannel summary command because this command shows you only the status of EtherChannels configured on an additional switching module(s) in this router. EtherChannels configured on routed ports do not show up in this output. So far, I haven't found a command that would show a similar listing - then again, as these routers have very few routed ports, the show interface Po1 usually is enough (it contains info about the member ports).
Best regards,
Peter
8 Replies 8
Reza Sharifi
Hi Sarah,
sw
Reza
Hello Reza,
Router:
no shutdown
Switch:
interface Vlan5
Router:
channel-group 1
no shutdown !
channel-group 1
no shutdown
Switch:
interface Vlan5
Best regards,
Peter
Hi Peter,
You are correct.  In this case, this config should work fine too.  What I was trying to say is that you need IPs on both sides. It could be under the SVI or PO interface.
Reza
Hi Reza,
Yes, absolutely. I also acknowledged that.
Best regards,
Peter
Hi Reza and Peter.
Please correct me if I am wrong.
Hosts-------sw-------ethechannel-------Router
We can configure at router site as :
int f0/1
channel-group 1
int f0/2
channel-group 1
int port-channel 1
ip address 199.199.199.1/24
at sw site:
Int range f1/1-3
switchport
As long as hosts and router are on same subnet, they should be able to reach router over etherchannel regardless of the ip address under svi at switch.
Thanks Peter and Reza.
Let suppose we have two slots on our switch i.e slot 0 and slot 1
Slot 0 has  f0/0, f0/1
slot 1 1 has f1/0,f1/1
Can we put ports from these both slots into a same etherchannel bundle say port channel 1 ?
Thanks and have a great day.
Hi Sarah,
It depends on the hardware and the IOS.
Most newer devices support Etherchannel within the same blade, between multiple blades and now for example with 6500 VSS between switches or in a case of 3750 stacked also between switches.
Can you provide the type router/switch and the IOS version you are using?
Reza
mahmoodmkl
Level 11
Level 11
i suggest tht u assign any vlan to the interfaces and check if it works as i can see default config for u r interfaces
