Layer 3 switching on Cisco WS-C2960X-48FPD-L
huwyhuwy123
hi All,
I've 2 Q's I'd like some help with
  1. We have bought some Cisco WS-C2960X-48FPD-L switches – do they do Layer 3 routing out of the box?
  2. Assuming the answer to the above is no, can we do a software update to the above or have we bought the wrong kit?
Really appreciate any help with this.
Cheers,
Huw
Dragan Ilic
Level 4
Level 4
I think that X series of switches have "IP lite" version (something like 2960-XR) which have most of L3 functionality.
Upgrade from one IOS (LAN lite to LAN Base or IP lite) is not supported - you have to buy in start adequate version...
BR,
Dragan
HTH,
Dragan
Thanks Dragan. So just to make sure I've understood, are you saying we can't upgrade the WS-C2960X-48FPD-L and will need to buy new switches?
Cheers,
H
You can't upgrade - and you need XR 2960 switch...
BTW you can do static routing and intervlan routing with LAN base if thats enough for you..."sdm prefer lanbase-routing"
BR,
Dragan
HTH,
Dragan
xavier.le-goff
  •  WS-C2960X-48FPD-L , L is for LANBASE Software Image so it should support basic static routing.
  • WS-C2960X-48FPD-LL , LL is for LANLITE Software Image that do not support basic routing, and I am not sure, but it cannont be upgraded to LANBASE image [it was the case for the first version of C2960 LANLITE].
Best regards,
XLG.
