layer3 access switch
bluesea2010
Level 5
Level 5
when buying a layer 3 access switch , what  parameters I have to take care of  .
Planning to buy 9300 series
balaji.bandi
Mainly License part, you need network advantage License, If you using DNAC then you need to look DNAC Licese here.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-swit-ser-cte-en.html
Other notes :
1. what uplink Modules and speed.
2. stackking cables (if you are stacking)
3. right SFP and ports (ethernet ports or SFP ports)  or mGig ports.
BB
common for all switches -
- number of ports and speeds required
- PoE or non PoE
- if PoE is using, how much power budget
- MAC address table size
- throughput
- uplink modularity and options
- power sources and redundant options
- stacking options
- SFP compatibility for SFP switches
-QoS if required
-storage and memory
- VLAN capacity
- monitoring capabilities
additional For L3 switches-
- routing protocols supported
- IPV4 and V6 route capacity
- TCAM capabilities
- in cisco SD Access capabilities, if you are planning to use
this are quick things comes to my mind to check.
Good luck
KB
Hi  @balaji.bandi
usually  what  would be tha mac address table size ?
Good presentaion help you : Cat 9300 architecture.
https://www.ciscolive.com/c/dam/r/ciscolive/us/docs/2018/pdf/BRKARC-3863.pdf
BB
