Line Protocol problem?
sherlon86
Community Member
Ethernet0 is up, line protocol is down
  Hardware is QUICC Ethernet, address is 0010.7bf2.3638 (bia 0010.7bf2.3638)
  Internet address is 193.1.1.4/24
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec, rely 128/255, load 1/255
  Encapsulation ARPA, loopback not set, keepalive set (10 sec)
  Last input never, output 00:00:03, output hang never
  Queueing strategy: fifo
  Output queue 0/40, 0 drops; input queue 0/75, 0 drops
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     395 packets output, 25359 bytes, 0 underruns
     395 output errors, 0 collisions, 1 interface resets
     395 lost carrier, 0 no carrier
Hitesh Vinzoda
Level 10
Level 10
Very good question without a question...!!!
It is physical layer issue reliability is very low and Lost carrier denotes you have a bad cable or check the physical connections on both sides.
BTW, any luck with setting speed and duplex manually on both sides. ?
Hitesh Vinzoda
Pls rate useful posts
sherlon86
Community Member
sorry forgot to say it is to connect to this ethernet port using cat5e cable.
The ethernet port setting from show interface command are :
Ethernet0/0 is up, line protocol is down
  Hardware is AmdP2, address is 0008.21d9.e1c0 (bia 0008.21d9.e1c0)
  Internet address is 192.168.1.1/24
     reliability 128/255, txload 1/255, rxload 1/255
  Keepalive set (10 sec)
  Last input never, output 00:00:02, output hang never
  Output queue: 0/40 (size/max)
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     192 packets output, 11818 bytes, 0 underruns
     192 output errors, 0 collisions, 2 interface resets
     192 lost carrier, 0 no carrier
Hitesh Vinzoda
Level 10
Level 10
Hitesh Vinzoda
