Link aggregation possible with 892FSP?
SilentHunter124
Community Member
Hi *,
I have a little question. Is it possible to take two Gigabit Switch-Ports of a 892FSP Router and aggregate these with a non cisco switch?
lauresfrank
Level 2
Level 2
Hi!
unfortunately not. I have the same issue. You can create Port-Channels itself, but command is not available under interface commands.
I dont know why they they disabled it, it is just a software limititation I guess.
C892-(config-if)#int port-channel 10
C892-(config-if)#exit
C892-(config)#int gigabitEthernet 1
C892-(config-if)#channel-group ?
% Unrecognized command
