Linking a Cisco layer 3 Switch with 2 vlans to a Sophos XG310 firewall
wfirth2012
Hi so im wanting to link a cisco layer 3 switch with two vlans and then once it goes through to the firewall and then once it arrives at the firewall i want it to send the traffic to the right vlan
@wfirth2012 hi, this is possible.
Option 1 - create trunk between switch and firewall. then configure VLANs on firewall and gateway IP at firewall. so every user will use firewall as gateway and you can filter traffic between VLANs at firewall.
Option 2 - create new network between firewall and switch. configure VLANs on L3 switch and enable IP routing. then configure default route to firewall IP. in this scenario, you cannot filter inter VLAN traffic at firewall.
Good luck
KB
Perfect i will have a go at these
