Linking two switches via Gbic problem
Group IT
I am trying to link a 3560 and 2960 switch via fiber. Both switches have 2x gbic ports. I have connected a GLC-SX-MM Gbic adaptor into the Gb0/2 port on both switches and used the appropriate fiber leads to connect to the fiber panel.
The fiber panel was installed by a third party, but they advised which leads to purchase, so I am quite sure they are correct. I have also done what research I could to ensure my Gbic adaptors are correct as per the lead spec and advice.
I have setup about a dozen or so Cisco switches/routers before but never had to configure gbic/fiber, so please bear with me .
So, I have everything plugged in, and I have assigned my Gb0/2 ports on each switch to the same VLAN, assuming they would just 'see' each other, as though I was connecting two switches via a cat5, but it doesn't appear to be working.
Am I forgetting something really basic, or Is there anything special I need to do in order to configure/enable these gbic adaptors? Both switches appear to register the adaptor but report the relevant ports as down:
ms-h002306>sh int gigabitEthernet 0/2
GigabitEthernet0/2 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 7010.5c31.9bb2 (bia 7010.5c31.9bb2)
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive not set
  Auto-duplex, Auto-speed, link type is auto, media type is 1000BaseSX SFP
  input flow-control is off, output flow-control is unsupported
Any help or advice would be much appreciated.
Thank you!
Elliot
10 Replies 10
Reza Sharifi
Hi Elliot,
This message indicated that you have no connectivity between the switches.  There is no difference between configuring a copper port vs fiber.
If you are sure that the fiber and optics are good then lets try switching the fiber strands around on one side of the connections and test again. You maybe connecting TX to TX vs TX to RX.
Also, are you using the correct optic with correct fiber:
for 1000BaseSX SFP you need Multimode fiber.
Plz clarify on the below points.
How you're connected the switches ? Is there any patch panel involving inbetween?
Are you using the same  GLC-SX-MM module both the side?
If you're using WS-C3560E, the minimum IOS should be 12.2(40)EX
What's the IOS version running?
Could you post the show running, show version , show inventory and show interfaces XX ?
What's the exact model of the 2960 switch??
I doubt it whether GLC-SX-MM module would support on 2960 switch. However plz chk with the
Cisco Gigabit Ethernet Transceiver Modules Compatibility Matrix by using below link.
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
Amir
On one of your switches try reversing the pairs.
Hi all,
Thank you for your replies thus far. I will try and answer all questions:
The 2960 is a WS-C2960-48TC-S with IOS v12.2(53r)SEY3. According to the link you provided it should support my GLC-SX-MM module with its current IOS.
The 3560 is a WS-C3560V2-24TS with IOS v15.0(1)SE.
Yes, the fiber is multi-mode. This was advised to me by the fiber engineer. He also specified the LC to SC 50/125 configuration.
My connectivity is as follows:
3560/Gbic--> multimode fiber lead -> fiber panel <-- multimode fiber lead <-- 2960/Gbic
These are the Gbic modules I am using at both ends: http://www.misco.co.uk/Product/46742/Cisco-GE-SFP-LC-connector-SX-transceiver
And the leads: http://www.misco.co.uk/Product/154824/C2G-1m-Lc-sc-Duplex-50-125-Multimode-Fibre-Patch-Cable
When you suggest switching the fiber strands around, are you implying I physically mess with the work the fiber engineer has done? The fiber leads I have don't appear to be easily reconfigurable, at least without the risk of breaking them.
I will advise additional config info in a second post.
Thank you all for your help!
Elliot
DETAILS FOR 2960
ms-h002306>sh inventory
NAME: "1", DESCR: "WS-C2960-48TC-S"
PID: WS-C2960-48TC-S   , VID: V06  , SN: FCQ1708Y7UZ
NAME: "GigabitEthernet0/2", DESCR: "1000BaseSX SFP"
PID: Unspecified       , VID:      , SN: AGM1708L1HM
ms-h002306>sh ver
Cisco IOS Software, C2960 Software (C2960-LANLITEK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 09-Feb-12 19:11 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01400000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(53r)SEY3, RELEASE SOFTWARE (fc1)
ms-h002306 uptime is 2 days, 16 hours, 59 minutes
System image file is "flash:/c2960-lanlitek9-mz.122-55.SE5/c2960-lanlitek9-mz.122-55.SE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960-48TC-S (PowerPC405) processor (revision M0) with 65536K bytes of memory.
Processor board ID FCQ1708Y7UZ
Last reset from power-on
2 Virtual Ethernet interfaces
48 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 70:10:5C:31:9B:80
Motherboard assembly number     : 73-12596-06
Power supply part number        : 341-0097-03
Motherboard serial number       : FCQ17080LPR
Power supply serial number      : DCA170486YN
Model revision number           : M0
Motherboard revision number     : A0
Model number                    : WS-C2960-48TC-S
System serial number            : FCQ1708Y7UZ
Top Assembly Part Number        : 800-32804-02
Top Assembly Revision Number    : A0
Version ID                      : V06
CLEI Code Number                : COMSG00ARC
Hardware Board Revision Number  : 0x0B
Switch Ports Model              SW Version            SW Image
*    1 50    WS-C2960-48TC-S    12.2(55)SE5           C2960-LANLITEK9-M
Configuration register is 0xF
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.07.22 10:21:34 =~=~=~=~=~=~=~=~=~=~=~=
ms-h002306#sh run
Building configuration...
Current configuration : 6937 bytes
version 12.2
no service pad
service password-encryption
hostname ms-h002306
boot-start-marker
boot-end-marker
no logging console
enable secret 5 xxx
username administrator privilege 15 secret 5 xxx
username ccpuser privilege 15 secret 5 xxx
aaa new-model
aaa authentication login default local
aaa authentication enable default enable
aaa authorization exec default local
aaa session-id common
system mtu routing 1500
ip domain-name hayley-group.local
ip name-server 10.11.1.217
crypto pki trustpoint TP-self-signed-1546754944
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1546754944
revocation-check none
rsakeypair TP-self-signed-1546754944
crypto pki certificate chain TP-self-signed-1546754944
certificate self-signed 01
  30820255 308201BE A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31353436 37353439 3434301E 170D3933 30333031 30303031
  30305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 35343637
  35343934 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BC68 78CC6DD2 7F605761 3DC60349 7919949B 51A22D68 940B5FBA 1643A16D
  34B13AB7 775DB5FA EE92A5B8 4409FFDF 4090A30D 86F6ECB3 2783FBEA F6ED3FE2
  675DE132 B0035282 764DE04A D9C0454A 3955A947 8F2D23C2 8790C55C 155C6B8F
  9247EEF4 6569629F E2C9A1DC 18FE5386 CC05688D 84549313 013FBE62 BC575D93
  F5D70203 010001A3 7D307B30 0F060355 1D130101 FF040530 030101FF 30280603
  551D1104 21301F82 1D6D732D 68303032 3330362E 6861796C 65792D67 726F7570
  2E6C6F63 616C301F 0603551D 23041830 168014C5 F35F8450 698A6CA1 7086B952
  5BD3F11B E366BD30 1D060355 1D0E0416 0414C5F3 5F845069 8A6CA170 86B9525B
  D3F11BE3 66BD300D 06092A86 4886F70D 01010405 00038181 005C65E4 6A9B33BD
  34789990 8ED2D13D 9846A04A AF11603C 0DA31E86 97E6B2CB 1AE93E6A 53CC95BC
  D9956E3A E3C5D4A2 C41CA5E9 DD348D2C EB413293 FD29C1C1 FBD137F4 09D19DD2
  8B02A9CE 2408C013 0F8FF339 EFA9A31C 4220D0BF 41DBAFE3 29F1B362 6BBACBBB
  BCD7691D CACA2F4F 4F28C976 35D2E1E1 B9201038 87EAB926 BD
  quit
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport access vlan 23
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface FastEthernet0/27
interface FastEthernet0/28
interface FastEthernet0/29
interface FastEthernet0/30
interface FastEthernet0/31
interface FastEthernet0/32
interface FastEthernet0/33
interface FastEthernet0/34
interface FastEthernet0/35
interface FastEthernet0/36
interface FastEthernet0/37
interface FastEthernet0/38
interface FastEthernet0/39
interface FastEthernet0/40
interface FastEthernet0/41
interface FastEthernet0/42
interface FastEthernet0/43
interface FastEthernet0/44
interface FastEthernet0/45
interface FastEthernet0/46
interface FastEthernet0/47
interface FastEthernet0/48
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan23
ip address 10.11.23.251 255.255.255.0
no ip route-cache
ip default-gateway 10.11.23.254
no ip http server
ip http secure-server
snmp-server community hgp-switches RO
snmp-server location Halesowen Unit 2
snmp-server contact Group IT
snmp-server chassis-id ms-h002306
line con 0
line vty 0 4
exec-timeout 0 0
privilege level 15
line vty 5 15
exec-timeout 0 0
privilege level 15
end
ms-h002306#
DETAILS FOR 3560v2
ms-h001837#sh inv
NAME: "1", DESCR: "WS-C3560V2-24TS"
PID: WS-C3560V2-24TS-E , VID: V05  , SN: FDO1519X2YA
PID: Unspecified       , VID:      , SN: AGM1708L1JM
ms-h001837#sh ver
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 15.0(1)SE, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 20-Jul-11 06:02 by prod_rel_team
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(53r)SEY4, RELEASE SOFTWARE (fc1)
ms-h001837 uptime is 9 weeks, 5 days, 17 hours, 37 minutes
System image file is "flash:/c3560-ipservicesk9-mz.150-1.SE/c3560-ipservicesk9-mz.150-1.SE.bin"
export@cisco.com.
cisco WS-C3560V2-24TS (PowerPC405) processor (revision L0) with 131072K bytes of memory.
Processor board ID FDO1519X2YA
4 Virtual Ethernet interfaces
24 FastEthernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 58:35:D9:53:D1:80
Motherboard assembly number     : 73-12636-01
Power supply part number        : 341-0328-02
Motherboard serial number       : FDO15200CMY
Power supply serial number      : LIT15100FDK
Model revision number           : L0
Motherboard revision number     : B0
Model number                    : WS-C3560V2-24TS-E
System serial number            : FDO1519X2YA
Top Assembly Part Number        : 800-33980-01
Top Assembly Revision Number    : B0
Version ID                      : V05
CLEI Code Number                : COMKZ00DRB
Hardware Board Revision Number  : 0x01
*    1 26    WS-C3560V2-24TS    15.0(1)SE             C3560-IPSERVICESK9-M
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.07.22 10:35:12 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Current configuration : 5346 bytes
! Last configuration change at 00:47:14 UTC Thu May 6 1993 by administrator
version 15.0
no service pad
hostname ms-h001837
boot-start-marker
boot-end-marker
no logging console
enable secret 5 xxx
username sas-admin privilege 15 secret 5 xxx
username ejohnson privilege 15 secret 5 xxx
username administrator privilege 15 password 7 xxx
aaa new-model
ip routing
crypto pki trustpoint TP-self-signed-3646148992
subject-name cn=IOS-Self-Signed-Certificate-3646148992
rsakeypair TP-self-signed-3646148992
crypto pki certificate chain TP-self-signed-3646148992
  3082025A 308201C3 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  69666963 6174652D 33363436 31343839 3932301E 170D3933 30333031 30303031
  30335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 36343631
  34383939 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CADF 226D3C0F 2E0E8CDA AEFDE358 E34BFF26 C748F190 2BD671C2 557190C5
  6B443BAC B0C54D76 54848149 08349F83 5719CA98 988A274E 3EB6530E C47B7DBF
  9F75DEC2 77082155 47E3B7FD C1794709 2877F647 F3D2F505 FF001B71 9F8E1A94
  360EEB6D 68990C20 1DCA7330 77244BCA 1AA736CE 548949DE 24372BFE E0E4BE85
  02C90203 010001A3 8181307F 300F0603 551D1301 01FF0405 30030101 FF302C06
  03551D11 04253023 82216D73 2D687132 2D683030 31383337 2E686179 6C65792D
  67726F75 702E6C6F 63616C30 1F060355 1D230418 30168014 1E09384B BC4E2824
  F84BDC52 DE6F5D07 09C7D930 301D0603 551D0E04 1604141E 09384BBC 4E2824F8
  4BDC52DE 6F5D0709 C7D93030 0D06092A 864886F7 0D010104 05000381 81007C33
  9CA8126B E91B6657 D0213595 F7D2C79A 966C72E1 50038BB6 1F7BE7C7 077DB6E0
  EDC4E464 515348F9 65D3B963 7174E7FE E3B67C63 4CD4CD38 FC4AA19D 7BF8ABDA
  91F0804E 10D9D977 8C22EEAE B2203B3D 09C9D27E AC8A7A2C 3E8B939E EF7DCCD5
  621B6240 4F45590E BBD2F143 D5EA1A01 B10D4E26 51EEE871 39C86C8F 61F7
            quit
description Direct link to LES10
switchport access vlan 21
speed 10
duplex full
switchport access vlan 22
description test vlan23 port
description Uplink from Nortel BayStack switch
description Direct link to SAS Cisco 1941 router
description Link to unit 2 switch
interface Vlan1
no ip address
shutdown
interface Vlan21
description EIGRP Peering
ip address 10.11.21.2 255.255.255.252
interface Vlan22
description VLAN22 (10.11.22.0 subnet)
ip address 10.11.22.246 255.255.255.0
ip helper-address 10.11.200.3
standby 22 ip 10.11.22.254
standby 22 priority 115
standby 22 preempt
interface Vlan23
description Unit 2 VLAN
ip address 10.11.23.246 255.255.255.0
standby 23 ip 10.11.23.254
standby 23 priority 115
standby 23 preempt
router eigrp 11
network 10.11.21.2 0.0.0.0
network 10.11.22.246 0.0.0.0
network 10.11.23.246 0.0.0.0
ip default-gateway 10.11.22.254
ip http server
ip http authentication local
logging esm config
privilege exec level 0 enable
line con 0
privilege level 15
line vty 0 4
exec-timeout 15 0
privilege level 15
line vty 5 15
exec-timeout 0 0
privilege level 15
transport input none
end
ms-h001837#
Hi all,
I came across this article: http://voices.yahoo.com/configure-vlan-trunks-cisco-switches-1774003.html?cat=15
So have adjusted my 2960's Gb0/2 interface as follows:
switchport trunk native vlan 23
switchport mode trunk
media-type sfp
I also adjusted my 3560's Gb0/2 interface as:
Unfortunately, this hasn't made any difference.
Based on the output of "#sh interfaces gigabitEthernet 0/2" (in previous posts), is it the physical link I should be concerned about at this stage, and not the VLAN config etc?
Woohoo, I think it's cracked!
Eventually I plucked up the courage to take the fascia off the fiber panel and started working out if it crossed over at any point leading back to the other of the line. It didn't appear to cross-over at all so I decided to fiddle and managed to swap one of the fiber coupling in the panel over.
Both interfaces came up! I started seeing a flashing light on the switches! And my test laptop picked up an IP from across the fiber. Excellent
Thank you all for your help folks, but one last question if I may... shall I keep my "trunk" setup as is now? Or remove the trunk settings to how they were before?
Thanks.
Elliot
Top man!!
Man,
You are my hero, you save my night. I made exactly what you did and it works!!!
I owe you a tequila bottle.
