Load Balance
cnuvo
Community Member
In 12.3T Cisco increased the number of BGP equal path links from 6 to 16. Does any one knows if they increased for the OSPF and static routes as well. Is there any supporting document on Cisco web sites?
Thanks in advance..
mohammedmahmoud
Level 11
Level 11
Yes it is, for static routes this was added by default, for all the routing protocol you must use the command "maximum-paths".
HTH,
Mohammed Mahmoud.
I searched Cisco web site and can not find it this info, I just need to know which IOS I need to have in order to allow 12 equal path load sharing for either static or OSPF.
Any IOS 12.3(2)T and later should support this for you.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00801a7f79.html
HTH,
Mohammed Mahmoud.
