Logging On Syslog
Sabby0115
Hello Friends
I have a question, is there any way to configure (logging or snmp on) the router so it can send all the typed cmd to syslog sever?
Sabby
Ivan Shirshin
Hi Sarbjit,
There is a way to do that using the EEM script. A very good example can be seen in Ivan Pepelnyak blog:
http://blog.ioshints.info/2006/11/cli-command-logging-without-tacacs.html
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
5 Replies 5
Ivan Shirshin
Hi Sarbjit,
Kind Regards,
Ivan
Kind Regards,
Ivan
Sandeep Choudhary
HI Sarbjit,
Yes you can .
Check out this web and attached document.
http://www.2000trainers.com/ccda-study-guide/snmp-configuration/
please rate if it helps.
Sabby0115
Thanks friends
Srinivas N
Level 4
Level 4
For syslog server, another easy way is some third party softwares also is there like... kiwi syslog server.........
Thanks & Regards,
Srinivas.
Hi Sarbjit,
If you are satisfied with these above  answers then please mark this question as answered, It can be it helpful for others.
