login and psw
ogadri
Someone could please provide me the command i need to place (on 3560 EMI and 6509 IOS, but i think it's the same) in order to change login and psw for telnet and consolle access. (with ecritption too) thanks,
simone
sourabhagarwal
Level 4
Level 4
use "service password-encryption" command in config mode to encrypt passwords.
To change telnet and vty password, configure new password under interface config mode and you should be good to go.
line vty 0 4
password
linet console0
password
HTH, rate if it does ....
