looking for Cisco Catalyst 3500 XL (3548) 48 port switch flash files
magyshanks2020
I want to upgrade the cisco version as the version installed not supporting ip dhcp snooping trust.
 know the switch is end of cycle but its still working
i dont know where to get its software files
8 Replies 8
balaji.bandi
Since its EoL. you many not get as support, do you have CCO account then you can download.
or google it you lucky enough to get one, hope this is for your Lab not for commercial use ?
or time for move to new models of replacement.
BB
magyshanks2020
  1. which one is the latest version?
c3500xl-c3h2s-mz.120-5.WC13. bin
c3500xl-c3h2s-mz.120-5.WC14 .bin
c3500xl-c3h2s-mz.120-5.WC16 .bin
c3500xl-c3h2s-mz-120.5.2-XU .bin
c3500xl-c3h2s-mz.120-5.WC17 .bin
/c3500xl-c3h2s-mz.120-5.WC7 .bin
c3500xl-c3h2s-mz.120-5.XW. bin
Hello @magyshanks2020
this should be the latest. However, the device was considered old more then 10/12 years ago so I am not sure that it supports DHCP snooping.
Hope to help
Giuseppe
ss
Not Supporting DHCP snooping i got this version already and whenever i type DHCP Snooping command... i get invalid marker
Hello @magyshanks2020 ,
as I have tried to explain the C3500XL is very old. They had a way to create a stack using proprietary 1Gbps optics.
In order to support DHCP snooping you would need a true multilayer switch with powerful ASIC,  TCAM and CPU.
The C3500XL should be just a plain L2 switch not powerful enough to support a feature like DHCP snooping.
Hope to help
Giuseppe
Leo Laohoo
WC17 is the latest and the last firmware version.
"XU" is the Interim Version which is what the factory loads.  XU is not meant to used in production.
2900/3500 do not support DHCP snooping.
ok so no neeed upgrade then worthless
