Loop occurs when connecting between Cisco Nexus switch and Alteon swit
김선명
hello
An additional VLAN 72 link has been connected between the Alteon L4 and the Nexus switch as shown in the photo below.
However, a loop occurred.
I connected, expecting STP to work for each VLAN, but the service was interrupted.
What on earth is the problem...?
Cisco : rapid-pvst
Alteon : STP/RSTP
Alteon : only stg 1 group
Mark Elsen
            - You need to make sure that both platforms use the same       ->STP algorithm
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi @Mark Elsen
Alteon is compatible up to RSTP, and Cisco is Rapid-Pvst.
Cisco Raipd-pvst was listed as 802.1w compatible.
Thank you
This vlan is vpc vlan or non vpc vlan?
Hi @MHM Cisco World
I'm not using a VPC. Non vpc vlan!
Thank you
