Lose config on 6506 switch
burleyman
Level 8
Level 8
After a power off of our switch we keep losing the config. I have made sure the start config and running config are the same. What I did find is the config register is set to 0x9006???? I have never seen this....can someone enlighten me as I think this is the problem. The config stays under normal operation just gets lost on power off and on.
Mike
Anand Narayana
Level 6
Level 6
Hi Mike,
config register 0x9006 means "enable diagnostices & ignore NVRAM & also the baud rate is 1200" set the config register as 0x2102 or 0x2 for normal operation.
hope this helps.
Anand Narayana
Level 6
Level 6
Hi Mike,
hope this helps.
That is what I thought but I just wanted to check. I have since found a Config reg tool that told me just that.
Mike
Hi Mike,
if this issue is been solved, please update in this forum as it might be helpful for others.
Anand
