mac flapping issue
surjinp07@
hi
please go through my log
%SW_MATM-4-MACFLAP_NOTIF: Host 108e.e057.6610 in vlan 1 is flapping between port Po1 and port Gi1/0/3
*May 13 12:58:47.132: %SW_MATM-4-MACFLAP_NOTIF: Host 108e.e057.6610 in vlan 1 is flapping between port Gi1/0/3 and port Gi1/0/5
*May 13 13:12:01.689: %SW_MATM-4-MACFLAP_NOTIF: Host 262a.915b.898d in vlan 1 is flapping between port Gi1/0/13 and port Gi1/0/6
*May 13 13:33:45.446: %SW_MATM-4-MACFLAP_NOTIF: Host 108e.e057.6610 in vlan 1 is flapping between port Gi1/0/13 and port Po1
*May 13 13:50:31.430: %SW_MATM-4-MACFLAP_NOTIF: Host c2f6.69d2.a401 in vlan 1 is flapping between port Gi1/0/16 and port Gi1/0/8
*May 13 13:54:25.971: %SW_MATM-4-MACFLAP_NOTIF: Host 108e.e057.6610 in vlan 1 is flapping between port Po1 and port Gi1/0/13
*May 13 16:26:27.959: %SW_MATM-4-MACFLAP_NOTIF: Host 108e.e057.6610 in vlan 1 is flapping between port Gi1/0/10 and port Gi1/0/12
how to solve this issue interface Gi1/0/3 to 16  used for wirless ap .i check these mac address it is just user mac example apple watch mobile phone .there is one port channel also there  Gi1/1/1  to Gi1/1/4 it is connected to the standby core switch. this switch is primary core switch 3650 cisco
how to solve this .now we are facing intereuption in wifi network also
Reza Sharifi
Maybe an STP issue and hard to tell without knowing how your network is connected. Is there a way to down Gi1/1/1  to Gi1/1/4 or Po1 and see if the problem goes away? You may want to make the change during off-hours as it could be disruptive.
balaji.bandi
I have seen this issue more of the network Wireless roaming - but this was not caused by any network issue as we have seen,
if this is only 2 MAC flapping, should not cause, but as suggested worth looking at any spanning tree issue, make a small network diagram, and investigate end to end.
you did not give any AP and wifi device information here,  have you seeing this issue from Long or recently started mainly you mentioned the wifi network issue ?
how about a wired network? is that working as expected?
BB
