Maintenance on VSL link
Colin Mans
Hi all,
Just looking for some quick confirmation from the experts here:
I currently have a VSS setup with 2 4510's and SUP7-E modules running production.
The VSL link is connected via 2 TenGig interfaces on the Supervisor board.
We will have to perform maintenance on the all VSL link ports to replace SFP's.
I would like to perform the maintenance without disrupting the VSL/VSS setup.
Can I just shut the port I will be performing maintenance on, replace the SFP and no shut it to bring it up again without disruption on the VSS/VSL and then repeat the process until all 4 SFPs are replaced?
I do not care about a couple of dropped packets, we will perform the maintenance during a window. I do however want to keep the VSS running as is.
As long as one VSL link is up, it should not disrupt the set up.
How ever do it in a maintenance window.
Madhu.
Madhu.
Thank you for your quick reply Madhu, greatly appreciated!
I would have thought so that no impact would be seen, but because it is the first time we will perform maintenance on our VSL, I want to better be safe than sorry.
Thanks again,
Colin
