manipulate ospf routing
Shibu1978
Hi all,
Basically we are having a Multicast setup.  both  A and B offices are being connected with STM-4 (622 Mbps) with IGP as OSPF. As of now everything is working well with this setup and no complaint .
Now since Primary link bandwidth is touching upto 622 Mbps  we are planning to send some traffic to backup STM-4 link
1) To send some vlan traffic always to backup STM-4 link here it is vlan 100 ( 10.20.6.0/24) what would be best way to do it.
Please find attached my network setup.
Any suggestion would be highly appreciated. Pl reply
22 Replies 22
Thanks will wait
Hi Rustom,
Do u have any update on this ..thanks
pille1234
Level 3
Level 3
How about changing the HSRP active Router for vlan 100 to the Backup-Router? Then increase the cost of the Etherchannel to at least 111 so that all vlan 100 traffic is routed over the backup line while all other vlans use the primary link.
Don't forget to do the same on the destination side or you'll witness asynchronous routing...
regards
Pille
Hi Pille,
Thanks for your suggestions.
Since we dont have contol on the other end i dont think we can do this work around.  i need to find a best & suitable way to do this from my side.  Is there any other way through which we can send the vlan 100 traffic( Multicast SSM) to Backup link? do u see any more options?
Sorry to be replying late. But it has been 2 days since I have been working with solutions for your network. Being a CCIE for routing switching, I had all the access to required equipment and hence had someone from my office setup equipment exactly as per your scenario. Even though chances of what you need to be achieving are bleek, I will publish result for what I have tried so far as to people who are willing to help you out can understand problems with the solution.
  • •1)      Initialy , I thought about manipulating metric for the prefix, but as I figure out that in a link state routing protocol, end to end visibility is important and hence, we at any point of time can change the link state database for 2 different routers. I means that all the routers need to have the same link state database. Hence the fisrt option of manipulating metric is lost.
  • •2)      Second I though about changing the administrative distance. I figured that maybe if we could change the AD of routes from 2 difference neighbours, the route with lower AD value would be preferred. :-P. Ok then I remember… blah…. Metric is preferred first, then the AD value.
So now I started to think out of best practises. Being a CCIE, it is important that we think out of the “BEST PRACTICE”fashion.
How about we have a static route with tracking via IP SLA on the backup  route device and redistribute it in ospf to the neighbour device with a lower metric. OK!!! . But it seems to have a problem.
OSPF will always prefer an intra-area route, then an inter-area route and lastly an external route. Hence even with a lower metric, the internal route across the primary link would be chosen.
Now I was in a fix, so we tried something else.
Like the above I did think about HSRP, but it will eventually follow the link which is preferred by OSPF. HSRP only will get information till the GATEways. They do not influence routing decisions. This decision is still OSPF.
And apart from that, the manipulation possible on only one side makes it even more difficult.
And so I started to think whether there was a way to manipulate Multicast so that we could just route the multicast traffic over the backup link.
But then think about something known as RPF. As multicast flows it will perform a reverse path forwarding for the packet at every hop. So till your OSPF routes don’t be pointing in the opposite direction, its not going to work.
I also though about creating static mroutes for the particular multicast traffic, but once applied, we could not failover to the primary path if the backup went down. Creating static mroutes with tracking is not an option.
So I am back to the square one. But am still working with the scenario. I have a couple of guys on my team work on it. Seems that we are closer to a particular solution, but it doesn’t seem best practise.
Will let you know tomorrow for any updates.
Rustom Billimoria
CCIE R/S#24798
Hi Rustom,
Thanks a lot for your efforts so far taken to fullfill my requirement.  really appreciated .no words.
If i dont find a best solution for my current requirement i may think about working out the below scenarios
1) Upgrade the STM-4 to STM 16
2) Request( somehow convince them) other end to static route to my new subnet 10.20.6.0/24  towards BACKUP STM-4 from their end both routers. I think this way i can get it done..hope there wont be any issue on the Multicast flow .
Kindly look in to 2nd option and let me know it is a workable solution.
Thanks again for efforts.
Hi Rustom,
Hope you are doing well.
Can u respond to my last query if possible. Thanks
Hi Rustom,
Any update on this. thanks
