manipulating stp
carl_townshend
Hi all, Can anyone tell me how to change the path that spanning tree takes, when uplinking a switch, would i just change the port cost ?
mahmoodmkl
Level 7
Level 7
The scenario depends upon how u topology is structured.How is ur topology design.
U can change the cost to force STP to work according to u r requirement.
Mahmood
