Cisco router--HP procurve duplex/speed issue
luke.bozeman
I have a cisco 3800 series router connected on the LAN side to an HP ProCurve 4000m switch. I can only get this connection to come 'up' at 10half (for speed/duplex) if I set both to auto, it negotiates to 10half. All other settings and the interface goes 'down' and will not come back up. I have tried new cables and other ports on the switch as well. Same issue. Any ideas?
Luke
8 Replies 8
Ahmede
We have the same issue, and we end up be leaving it at 10/half.. Can not explain why..
What HP firmware version are you at?
we are at Firmware C.08.03.... ROM C.06.01
We are at C.09.22, so it is not a firmware issue like I had initially thought.
obukev
We are running a Cisco 3825 Router with the following configuration:
interface GigabitEthernet0/1
description $FW_INSIDE$$ETH-LAN$
ip address x.x.x.x 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
load-interval 30
duplex auto
speed auto
media-type rj45
negotiation auto
no mop enabled
... and the 4000m has the following setup:
Type: 10/100
Intrusion Alert: No
Enabled: Yes
Status: Up
Mode: 100FDx
Flow Ctrl: off
Bcast Limit: 0
.... hope this helps.
you could try adjusting the carrier-delay time on the cisco box (under the interface config mode) after locking both end to say 100/Full.
Eg.
config t
interface g0/1
!Generally you want to raise the time
carrier-delay 4
Please rate if this helps.
HH
I will give this a try, all other attempts have failed.
Luke
Sorry did not work. I ended up using a small gbit switch between the router and the LAN switch. All issues have been resolved, however, I do not like this solution.
