Manual method in cellular interface
khaledsallam89
When i type this command , show my in br i found that the method in cellular 0/2/0 is manual with unassigned IP although the other cellular interface 0/1/0 is IPCP and can obtain the SIM IP normally.
Tried to test the SM Card in another modems and it is woring fine.
How to change the method from manual to IPCP?
M02@rt37
Hello @khaledsallam89,
Which model?
Do you try:
interface Cellular0/2/0
encapsulation ppp
ip address negotiated
--the specific commands and syntax may vary depending on the router model
Best regards
