Replacement for Cisco N2K2232PP-10GE
Karthik N
I need to replace below switches which are EOL, which switch would be better in line with these model ? please suggest. Thanks in advance.
N2K-C2232PP-10GE
N2K-C2248TP-E-1GE
N5K-C5596UP
N9K-C93180YC-EX
8 Replies 8
marce1000
   - Assuming you are aware as to the purpose of these devices on your network, you may for instance start searching (yourself) by looking at :
                                             https://www.cisco.com/c/en/us/products/switches/switch-selector.html
 M.
N9K-C93180YC-EX <<- you want to replace this NSK ? can I know why?
Hello, the EOL listed for N9K-C93180YC-EX is Aug 21 and EOS is Aug 24. Although its still time but not very urgent for this switch. Our organization is currently auditing for EOL and EOS ones and these are the ones being shown as EOS. Thats why asking for suggestions if this can be continued with a replacement model or shall we go continue with the same.
Thank you.
Hello Marce, yes I did check that link but unfortunately there are no suggestions for replacement beyond Catalyst 6880. Attached snapshot for reference.
Thank you.
 - In essence , it does not matter  , check 'what you need'  (replacing that device) in the network , for that purpose , use the switch selector -> start from scratch
 M.
M02@rt37
Hello @Karthik N,
Fabrice Extender N2k will not be replace. FEX is the old world now (lol).
You can switch to N5K or N9K series with back to back vPC configuration with your SW-CORE.
https://dmitrygolovach.com/cisco-nx-os-from-vpc-to-back-to-back-vpc/
Best regards
Fex is different than back to back vPC'
He can use nexus 9300 supoort fex
 https://www.cisco.com/c/dam/en/us/td/docs/Website/datacenter/fexmatrix/fexmatrix.html
I prefer he contact cisco sales engineer' he can give best solution within his budget
