mdix mode is different for ports using the same port-channel
robertkwild
hi all,
i have port ranges te1/0/1-2 in port-channel 1 but when i look at the individual ports by doing a #sh int status i can see "mdix mode" one is on and one is off
do they both need to be set to the same ie on or off or doesnt it matter?
many thanks,
rob
                                              Flow Link  Back       Mdix
Port Type Duplex Speed Neg  ctrl   State Pressure Mode
te1/0/1 10G-Combo-C Full 1000 Enabled Off Up Disabled On
te1/0/2 10G-Combo-C Full 1000 Enabled Off Up Disabled Off
cheers,
rob
Deepak Kumar
Are you facing any issue with Port-Channel? A port-channel will not check MDIX mode but it is mandatory that all members must work on the same speed and duplex.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
6 Replies 6
Deepak Kumar
Deepak Kumar
Deepak Kumar,
usually on by default in newer switches , wont make a difference really once your using same cables like straight through if copper , if its fibre or twinax as its 10GB wont make any difference
 basically this switch is connected to another switch via 2x1gig rj45 ethernets which i have made both sides into LACP (as you can see below)
switch A i am using the 10gig ports instead of the 1gig ports, will this make a difference?
switch A
Po1 10G Full 1000 Enabled Off Up
switch B
Gi2/1 connected trunk a-full a-1000 10/100/1000-TX
Gi2/2 connected trunk a-full a-1000 10/100/1000-TX
Po2 connected trunk a-full a-1000
The port-channel will never be performed because it is required at the same speed and duplex settings.
"Configure all LAN ports in an EtherChannel to operate at the same speed and in the same duplex mode".
The compatibility check includes the following operational attributes:
  • Network layer
  • (Link) speed capability
  • Speed configuration
  • Duplex capability
  • Duplex configuration
  • Port mode
  • Access VLAN
  • Trunk native VLAN
  • Tagged or untagged
  • Allowed VLAN list
  • MTU size
  • SPAN—cannot be a SPAN source or a destination port
  • Layer 3 ports—cannot have subinterfaces
  • Storm control
  • Flow-control capability
  • Flow-control configuration
All may change as per the hardware model and version.
Deepak Kumar
Deepak Kumar,
they are the same duple, speed as both port channels say connected and up
That's really good news. I hope you got your answer. Don't forget to vote a helpful answer and accept a solution which worked for you.
Deepak Kumar
Deepak Kumar,
